W166 Rear Seat Headphones + Command Engineering Menu
2014 ML 350 4Matic Gas
Hello all,
I have a 2014 ML 350 with rear seat entertainment. I bought a pair of OEM headphones new in factory packaging on eBay for $50 last week. They haven't arrived yet, but, I have been researching how to connect them to the car. The existing threads on COMMAND secret engineering menus don't go into detail on how to connect headphones. Although these existing threads are full of great info!!
There has to be a way to do this at home...
I have accessed the Engineering Menus in COMMAND and located a setting under 7.17 Headphone Setting. Unfortunately at this time it is grayed out.
Questions:
1. Is it grayed out because I don't own a pair of headphones yet? Makes sense, but, there are a lot of grayed out menu options.
2. If I have a pair of headphones in the car with fresh batteries will the menu item become accessible? If not, how do I make 7.17 an accessible menu item?
3. If I am no where near the right path to get this done with menu item 7.17, can someone out there give me some guidance? Alternatively, anyone have the pages that cover this out of a service manual?
4. Does anyone use non-OEM wireless headphones with the Rear Seat Entertainment system?
THANK YOU!!!
Questions:
THANK YOU!!!
I am not aware of any method other than using the Xentry diagnostic system. If you don't have this it requires a trip to the dealer. If another method exists, I am interested.
Also, you should be able to use non-OEM headphones that use Kleer lossless technology.
