Removing brake/power steering fluid from driveway - MBWorld.org Forums
Off Topic Use this forum to discuss non-Mercedes related items or anything that doesn't belong in the above forums.
Sponsored by : Liqui Moly
Click Here
LinkBack Thread Tools Search this Thread Rate Thread
Old 07-20-2010, 06:06 PM   #1
SeaCoupe's Avatar
Drives: 2002 C230K, 2013 BMW 328, 2015 BMW X5
So what do you guys use to get the fluid leaks off the driveway?
At HR girls house, there are some puddles forming. No, it is not from SeaCoupe. I swear, this w/e, I'm going to put cardboard under everyone's car to catch who it is.
Meantime, I want to get the spots off. Any advice?
Ed
SeaCoupe is offline   Reply With Quote
Old 07-20-2010, 06:09 PM   #2
revstriker's Avatar
Drives: K Car
Ed
Jackhammer.
revstriker is offline   Reply With Quote
Old 07-20-2010, 06:42 PM   #3
GBlansten's Avatar
Drives: 2014 BMW M5 SG/SS
I've heard that prayer changes things so you could try that.
You might also try to leave some kitty litter over the stained areas. That worked well on some motor oil recently.
GBlansten is offline   Reply With Quote
Old 07-20-2010, 06:42 PM   #4
Drives: His mama. Traded y0 mama in because she was squeaking.
Kitty litter then Brake cleaner.
But if your driveway is porous (like Cement) then brake cleaner, and lots of it.
Sathinas is offline   Reply With Quote
Old 07-20-2010, 07:07 PM   #5
JustPete's Avatar
Drives: CLS55 AMG 030
Ed
An engine degreaser (or solvent like brake cleaner, wd40,carb cleaner etc) and Oil-Sorb would be the way to go.
Last fall after changing the oil on the motors of my boat (2 - 5.7l v8's and 8+quarts of oil) I put the oil changer (A 5gallon bucket with a pump on top) in the back of my truck planning to dump the oil in containers when I got home.
I got home late and decided to do it in the morning not realizing that at some point looking like about the time I drove up my drive, the bucket fell over and all that oil spilled on my drive. I dumped oil-sorb all over it and cleaned up the bulk, then used a degreaser and more oilsorb after. I thought my driveway was basically ruined but I can't even find the stains anymore.
JustPete is offline   Reply With Quote
Old 07-20-2010, 07:28 PM   #6
Super Moderator
nlpamg's Avatar
Drives: 991 GT3, C117 AMG, W203
where do you get oilsorb from?
nlpamg is offline   Reply With Quote
Old 07-20-2010, 08:04 PM   #7
Bing's Avatar
Drives: C320 Sport Sedan 4MATIC, Cayenne S, Bayliner Capri V8, Subaru STi
checking my shelf..........ahh there it is!
ZEP Driveway and Concrete Cleaner at:
HOME DEPOT
Bing is offline   Reply With Quote
Old 07-20-2010, 09:05 PM   #8
Militant-Grunt's Avatar
Drives: 95 Audi urS6 Quattro
Muriatic Acid, you can buy it at any masonry place, does a pretty good job at removing oil.
Militant-Grunt is offline   Reply With Quote
Old 07-20-2010, 09:31 PM   #9
Drives: Kinda...
HOME DEPOT
What is the fascination with STI owners taking pictures of products on the massively oversized wing of their cars???????
emilner is offline   Reply With Quote
Old 07-20-2010, 09:39 PM   #10
Drives: a toy
Any of the chemicals mentioned + pressure washer. My driveway came out looking better than new.
Roupin is offline   Reply With Quote
Old 07-21-2010, 12:48 AM   #11
revstriker's Avatar
Drives: K Car
Quote:
You can also pick this up at most Home Depots / Lowes, or any Pool Supply stores.
Don't get it on your skin.
Old 07-21-2010, 02:07 AM   #12
SeaCoupe's Avatar
Acids tend to etch concrete and take off a top layer.
Some years back, I used muriatic acid to eat up the excess grout I couldn't sponge up on a porous ceramic tile I put in my house. Nasty stuff.
Old 07-21-2010, 04:39 AM   #13
VCA_AMG's Avatar
Drives: '12 E63 wagon w/pano
Quote:
VCA_AMG is offline   Reply With Quote
Old 07-21-2010, 06:18 AM   #14
Super Moderator
Nola's Avatar
Drives: Audi A5 Sportback + Cannondale Prophet
SeaCoupe? WTF?
Nola is offline   Reply With Quote
Old 07-21-2010, 10:21 AM   #15
revstriker's Avatar
Drives: K Car
Yes. I use MA on finished concrete when trying to bond mortar to it. Depending on the driveway though, this might not be too bad. Would still be a last resort.
Always seal the face (not the edges) of porous tile before grouting. Will save you a lot of elbow grease later on. I learned this lesson after installing a nice slate back splash for a customer. Ended up having to go over the entire thing with a little wire brush (golf club brush from my golf bag) in order to get the grout out of the crevices. Luckily I was able to do this before it set up.
Old 07-21-2010, 10:58 AM   #16
JustPete's Avatar
Quote:
I picked it up at the local hardware store. It's cheap. If I recall, about $3-5 a bag. Took me less than 2 bags to clean up all that oil.
It's similar to cat litter, but with properties that help it specifically grab oil molecules without the crap that makes it like cat litter. Cat litter is just absorbent but I don't think it breaks down oil.
Most marine stores carry oil sorb blankets and rolls for spills in water and bilge. Don't know if they sell the granules.
Old 07-21-2010, 11:00 AM   #17
JustPete's Avatar
If you use muratic acid on concrete, you need to reseal it or you're going to get spalling in the area you used it over winter. (assuming you live in an area that gets freezing winters)
Old 07-21-2010, 07:29 PM   #18
Gullwing's Avatar
Drives: 1987 190E 2.3
You can try California friendly brake cleaner, but if you want some that actually work you need to go to Nevada or Arizona.
Engine degreaser should work also.
Gullwing is offline   Reply With Quote
Old 07-21-2010, 09:27 PM   #19
electromethod's Avatar
Drives: 2K3 C230 Sedan
Ed, I actually took home from work some "institutional tide" for cleaning the concrete floors in the garage. It's not the same tide you use for laundering clothes. In foodservice, it's used for mopping floors because it cuts grease almost as good as grease cutting chemicals. Anyways, I scrubbed down the spots with it and a push broom. Let it sit there for 10 mins and repeated. Then I covered area for 2 days in backing soda to lift anything extra that got into the concrete. No joke, repeated the tide scrub and hosed it down after that. Now I can't tell where the puddles were.
electromethod is offline   Reply With Quote
Related Topics
Thread Thread Starter Forum Replies Last Post
Thunderhill Track Day kfehling C43 AMG, C63 AMG, C63S AMG (W205) 35 11-19-2016 10:56 AM
DIY Notes - Front and Rear Brake Pad and Rotor replacement, Brake Fluid Bleed, Flush DFac Boy C32 AMG, C55 AMG (W203) 1 09-07-2015 05:32 AM
loss power seats and tele-steering wheel heespaul S-Class (W140) 2 09-06-2015 04:46 PM
2006 SL500 Windshield Washer Reservoir sreckie SL55 AMG, SL63 AMG, SL65 AMG (R230) 0 09-04-2015 11:22 AM
FS: 2005 E320 4matic Estate marc hanna Mercedes Vehicles 0 09-02-2015 09:16 AM
Tags
brake, cement, clean, cleaning, concrete, degrease, driveway, driveways, fluid, leaks, power, remove, removing, steering, tide
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Copyright 2001-2012 InternetBrands, Inc. / MBWorld.org. All Rights Reserved.
