C320 Performance Thread
with pullies - you are not changing and of your elect's. however, you need to install a bigger pully on your alt. with the alt spinning at a higher rate - it will not charge like it is suppose to.
My 320 has
Wish List: SC, LSD, CF Driveshaft
- Evosports Underdrive Pulley
- AMS Aluminum Crank Pulley - Got +15 RWHP Dyno'd
- Custom made Headers by member GhostRhider
- Custom Air Intake made by member VIPclk320
- Free Flow Supersprint Muffler & Resonator
- Custom PowerChip ECU tune for 95 Octane
- Sprintbooster
- Okada Projects Plasma Direct ignition Coil
- NGK Iridium Plugs and Wires
kleeman w203 c320
So I'm wanting more power and I've heard a lot of ideas... I've also heard kleeman is the best flat out. I'm lucky enough to live in the same city as their U.S. headquarters... so it makes it cheaper lol... I am going to have them chip and tune my stock ecu to see what kind of difference it makes... I will be putting my car on the dyno before and after.. I thought I would try to help some people out with info on kleeman since I live here. I will have this chip and tune done before may is over
