Used Johnson CM30 Pump
2004 W211 E55K, GL550
Have for sale a johnson CM30 Pump about a 1.5 yr old with only about 7,000 miles on the pump. Thought i had a bad pump but came to find out i had a faulty intake air temp sensor. Tested the pump after i removed it from my car and the pump works perfect with great flow. Will let it go for 100.00 Shipped if anyone is interested. I even have the oem plug connected to it so it would be a straight plug and play for m113k motors no cutting up your oem harness.
