Go Back   MBWorld.org Forums > Site & Forum Support > Questions about how MBWorld.org works...not for car questions.
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Members Insurance Search Today's Posts Mark Forums Read CarsGarageVendors
Welcome to MBWorld.org Forums
Questions about how MBWorld.org works...not for car questions. Use this forum for help on using all or any part of the forums. Make sure to read the Forum FAQs first.
LinkBack Thread Tools Search this Thread Rate Thread Display Modes
Old 10-01-2010, 02:09 PM   #1
Drives: C126 500 SEC
Unhappy C/W126 UK 500 SEC Water Ingress Need Help Please!
Hi All,
I have read the many threads on water ingress and tracing leaks. My symptoms are a puddle in the rear passenger footwell and I have spotted a leak coming from the bulkhead above the front passenger footwell. (It is not the sunroof, all channels are fine and doing their job properly) I have just had the windscreen re-fitted and re-sealed but this did not cure the leak and I suspect it is coming from the base of the screen on the near side through a grommet area or the rubber seal that is supposed to channel the water into a drain area from the A post. I have cleaned all of the lower screen drain area's of leaf debris but still have the leak!
The upper A post drains are not leaking (I saw a similar post which pointed to these earlier)
Can anyone recommend a good shop in the UK (Preferably close to Sheffield/Nottingham) that can remedy water leaks? I spoke to my dealer and they do not want to touch it as it is a 20 year old car (Says pretty much all you need to know about Jct600...) Have now become desperate so any help at all would be gratefully received, I just sponged out about three litres from the rain today
The rear screen is leaking in the usual place but will not re-seal this just yet as the car is about to have a glass out repaint and don't want to do this twice in four weeks
To remove this ad, register today or login if you already are registered!
shkarus is offline   Reply With Quote
Tags
500, footwell, rear, sec
Search this Thread:
Advanced Search
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Copyright © 2001-2012 InternetBrands, Inc. / MBWorld.org. All Rights Reserved.
Everyone's Personal Details
SEO by vBSEO 3.5.2
