R-Class (W251) Produced 2006-2013: R320CDI, R350, R420CDI, R500
Headrest DVD system Installation
Old 09-06-2008, 12:19 PM
supernsx's Avatar
2011 C300 4matic, 2015 Porsche Macan S, 2006 R500 (sold)
Question Headrest DVD system Installation
I bought a Headrest DVD system on ebay and I am planning to installed it myself (hopefully) to my "new to me" used R500.
Before I start tackle the job, I am looking for some help to make the job easier:
1. I have a 06, so it doesn't come with the active head restraint system. Can someone help and let me know how I can remove the two front headrests? The car has the comfort package, so it comes with the power headrests.
2. I am looking for a 12V power source that is closed by the front seats. I know there are two 12V cigarette outlets underneath the rear climate control console. Does anyone know how to remove the cover(s), so I can tap to those power sources? ? Or there are other better power sources that I can use.
Thanks in Advance and I will definitely write up the steps during my installation.
Old 09-06-2008, 07:55 PM
rosswell's Avatar
S320 GL350
See STAR service manual library Model 251
Instructions to retrofit the MB DVD player that is mounted to the rear of the front console are included over four pages - and also for dismantling the headrests. I can't legally reproduce them "in whole or in part" but can tell you there's wires in the rear floor compartment where the battery is -and underneath the center console.
Old 09-09-2008, 11:03 PM
PREMIUM SPONSOR
rob13572468's Avatar
ML350, Lotus Elise
1. undo th two torx screws at the bottom of each seat back. that will expose the headrest posts which can then be rocked back and forth to detch from their clips. if you have non-motorized headrests then there is a metal clip holding them in.
2. best place to get power is the front cigarette lighter. undo the two torx screws under the cupholder, pull the side panels and remove the small black cover under the armrest. the whole center part will then be removable.
Old 09-10-2008, 06:21 AM
AsianR350's Avatar
08 R350, 07 Acura RL, 1989 Honda Shadow VLX600 (10K miles)
rob13572468,
Any pics or diagram of how to remove cup holder/ side panel to access to cigaretet socket?
Thanks in advance.
Old 09-10-2008, 03:49 PM
supernsx's Avatar
Rob,
Thanks for the great info. I am actually thinking about tab to the battery directly since it is really just underneath the seats..... any opinion on that?
Thanks again!!
Old 09-10-2008, 06:03 PM
AsianR350's Avatar
I suggest that you tap into center cigarette socket because it turn off when engine is off.
I have overhead DVD installed by my neighbor who owns a H & R radio installation store and he tapped into the cigarette socket near the passenger side. It will not turn off when the engine is off but it will turn off itself when battery is low.
Old 09-10-2008, 09:02 PM
supernsx's Avatar
Thanks. Do you know how I can tap to the socket? I look at console and don't know how I can take off the cover and get to the socket....
Old 09-10-2008, 09:08 PM
AsianR350's Avatar
I asked rob3572468 the same question how to remove the console to get down to the socket. I did it on my 07 Acura RL with the help from service manual. \
My neighbor (his assembler tapped the wire from below the glove box) but that is for passenger side not the center console.
Old 09-14-2008, 05:55 AM
PREMIUM SPONSOR
ML350, Lotus Elise
rob13572468,
Thanks in advance.
I looked and I dont have any pics of that sections apart. I should have an R class in this week and I can snap some pics to post.
Old 09-14-2008, 09:13 PM
AsianR350's Avatar
rob3572468,
That would be great.
Thanks in advance
Old 09-15-2008, 04:17 PM
vinceching's Avatar
2007 ML 500
thread hijack, but i've been trying to contact you via phone and email and haven't gotten a response for a long time.
can you please pm or email me details regarding your video in motion kit as well as the voice control retrofit for the 2007 ml. thanks
Old 09-26-2008, 10:06 AM
PREMIUM SPONSOR
ML350, Lotus Elise
R class center console removal
Got an R in the other day for a camera so I snapped some pics of the center console removal...
Attached Thumbnails Headrest DVD system Installation-r_console1.jpg   Headrest DVD system Installation-r_console2.jpg   Headrest DVD system Installation-r_console3.jpg   Headrest DVD system Installation-r_console4.jpg   Headrest DVD system Installation-r_console5.jpg
Old 09-26-2008, 12:46 PM
AsianR350's Avatar
rob13572468,
Thank you for the detail pics.
I had tried last time but could not figure it out @ the last 2 steps of the pics.
It is great to have you in this forum.
Old 09-26-2008, 05:29 PM
supernsx's Avatar
Rob,
This is awesome. I was just able to remove the console using your instruction and look at the lighter power outlet underneath it.
My next question is what will be the best way to tap to the power source there. It seems like there are many wires going there including an adaptor. Can you help and provide me some suggestion?
Btw, thanks for your earlier tips on removing the back panel. I was able to install the DVD headsets and all the wires inside the seats. Super easy there.... getting power is another story....
Thanks!!
Old 09-28-2008, 04:02 AM
PREMIUM SPONSOR
ML350, Lotus Elise
Rob,
Thanks!!
The harness to the cigarette plug has three wires: two thick and one thin. The thick brown wire is gnd. the other wire (usually a thick black/blue stripe or blue) is 12v switched. The easiest way to tap power is to use T-Taps whcih you can get at your local auto parts store. just make sure you get the large gauge ones (yellow)
Old 09-28-2008, 09:33 PM
supernsx's Avatar
Thanks again Rob. I would definitely go this route. Will post pictures when I am done.... hope to get it completed this weekend.
Old 10-07-2008, 11:30 PM
t4pizza's Avatar
2017 GLS 450
I am actually doing the exact upgrade to my "new to me" 2006 R350. I purchased the visualogic headrest on ebay but my dealer would not install so I have tackled the job myself. Finding this thread was a huge bonus. My only question is whether I need to tap into all three wires on the cig. lighter or just the two wires (switched and ground) that Rob described. Any help would be greatly appreciated. Thanks in advance.
Old 10-09-2008, 09:29 AM
PREMIUM SPONSOR
ML350, Lotus Elise
The vizualogic kit has 4 wires: Black,Green,Red,and Yellow
Black and Green go to the thick Brown at the cigarette plug.
Red goes to the thick black/blue stripe at the cigarette plug.
Yellow goes to the thick red wire on the back of the radio.
Old 10-09-2008, 05:19 PM
t4pizza's Avatar
2017 GLS 450
Thanks so much Rob. My only question now is how do I get to the red wire behind the radio? Another post spoke of taking out the hvac system first, but I cant seem to find the exact places to put the tools to take out the hvac system and therefore I can't get to the radio. Can you provide any pointers to help with this? Thanks in advance.
Old 10-09-2008, 06:31 PM
PREMIUM SPONSOR
ML350, Lotus Elise
you insert a pry tool between that panel and the leather trim on each side all the way at the top (e.g. just below the radio) and gently pry outwards. each side will pop out and then the entire panel can be removed. then undo two t-20 torx under the radio and slide the latches down. radio will slide out then.
Old 10-09-2008, 10:38 PM
t4pizza's Avatar
2017 GLS 450
Rob, i can't thank you enough. I had been feeling all around the hvac system with no luck. After your post I was able to get the radio out in less than 10 minutes. Not only was I able to finish the install on the headrest dvd but it allowed me to swap out the command for one with nav. Dealer told me that would take hours and would not do it since I bought the command with nav from another source. With your input it literally took less than 15 minutes, everything was prewired including the gps antenna. One night two projects done. Thanks again. You really are an asset on this board.
Old 10-11-2008, 05:11 AM
PREMIUM SPONSOR
ML350, Lotus Elise
no problem.. im happy to help...
btw, i take it you dont have teleaid on your R.... if you do and your navi isnt tracking the sats let me know and ill tell you what to do next...
Old 10-11-2008, 03:22 PM
AsianR350's Avatar
I bought T-tap (yellow color-12 gauge) @ Radio Shack and tapped into the cigarette plug but it made no contact.
Finally, I used T-tap (Blue color - 18/14 gauge) and have no problem.
Old 02-06-2009, 02:06 PM
ste
ste's Avatar
2005 MINI Cooper S Conv, 2006 R350
Vizualogic from S class?
I think I shall stay away from eBay, keep doing these impulse buying
Just saw a Vizualogic A1250 for 2007 S class. It's just a DVD player, with right color, and same shape of ones for our R class ... so I bought it. Right after, I am having the doubts ... if they are the same, why would they having different part#? 710792146510 vs 710-79054-XX ?
Guess I will find out when I can't install it after receiving it. help ...
Steve.
Old 02-12-2009, 04:51 PM
ste
ste's Avatar
I received the S class Vizualogic A1250 last night!
Very nervous to find out that the metal pieces that hold under the headrest plastic don't fit. That's why they have different ones for the SUVs. The Vizualogic sales service guy was not use at all, just told me to get the right type.
After twisting the metal for couple hours, I successfully got them ON! the metal just look tough, but easy to be bended.
Having a cup of coffee, and taking a break for my sore fingers. Will continue to do the power and radio connector later.
Another question is that, where did your guys put the control box? under/in the glove box? and how to wire to the glove box? want to connect to the aux input.
Quick Reply: Headrest DVD system Installation
