R-Class (W251) Produced 2006-2013: R320CDI, R350, R420CDI, R500
Center air vent removal
Old 07-28-2009, 06:23 AM
Zachmac's Avatar
2007 S600
Anyone got the WIS on removal of the center air vent nozzle (the assembly above the command com) in an R calss.
I need to put in a new one to replace the busted up one I created by stopping for the idoit who pulled out in fornt of me while hauling home long garden edging from Lowes laid across the center console. No the wife was NOT happy! At least the metal missile missed the command com!
BTW, lesson learned is that while the R class is a very flexible hauler it pays to take that extra minute to strap stuff down as there is a lot of nice expensive stuff to break if you have to stop quickly!!!
Old 07-28-2009, 09:27 AM
i_am_amused's Avatar
2004 S55 (SOLD, miss it every day), 2009 GL550
as you now know, loose cargo is not a good idea. you are extremely lucky, and should play the lottery before it wears off
Old 07-28-2009, 10:50 AM
Zachmac's Avatar
2007 S600
Vent removal
Gee thanks. Any insight iinto the actual problem?
Old 07-28-2009, 11:14 AM
lkchris's Avatar
'07 GL320CDI, '10 CL550
$18 will get you a 24-hr subscription to WIS.
http://www.startekinfo.com
Old 07-28-2009, 11:33 AM
Old 07-28-2009, 08:46 PM
Zachmac's Avatar
2007 S600
Vent all done!
All done. Just a matter of bending down (or up on the bottom) the eight tabes (two top and two bottom per vent in the housing) and pulling. Of course it helps when you aren't concenred at all about the piece being removed. I took some pliers and "removed" all the louvers first which makes getting to the tabs a breeze!
BTW, the replacement part had two wire connectors (one per vent) but the unit removed had no wiring. Anyone know what these might be for on another car or another option?
Old 06-08-2015, 10:48 AM
Ringfinger's Avatar
R500
Vents with electrical connectors
The elctrical connectors are for the interior lighting package that "lights up" the vent wheel adjusters. Thanks for the info!
Quick Reply: Center air vent removal
