Sign in using an external account
| R-Class (W251) 2006-Present: R320CDI, R350, R420CDI, R500 |
LinkBack | Thread Tools | Search this Thread | Rate Thread | Display Modes |
#1 | ||
Drives: 06 R360, 06 F350 6.0, 04 CayenneS, 96 911TT 500HP, 86 928S, 74 911S, 73 914-4, 70 914-6, 02 Durrango
Perfromance W272
__________________
2006 R-350 V6 Silver 65,000 Miles Michelin Latitude Tour HP R19 Hitch, 0W-40 Mobil 1 European, Drain Plug Every 10,000 Miles And Change The Filter Modified Grille = Ram Air Effect In Intake. Valoline Full Syn 75w-90 Front Diff and Rear Diff. Choosing an air filter: http://www.mbworld.org/forums/r-clas...ml#post4357145 |
#2 |
Bump Bump. Anyone have anything to add?
__________________
#3 |
__________________
#4 |
bump bump^^^^^
__________________
#5 |
bump bump to more upgrades
__________________
#6 |
You can also use Mobil 1 synthetic Diesel oil to improve performance due to it higher lubricating properties. I also has Gas engine API ratings.
Also I strongly suggest to not use mobil 1 ESP formula due to the VERY LOW lubricating properties compared to any other engine oil. And the 0w-40 oil is also a good oil but again, that is on the lower end of lubrication than other oils. I use half Mobl 1 TBD 5w-40 and half Mobil1 0W-40 in my MB and Cayenne.
__________________
#7 |
bump bump
__________________
#8 |
Drives: '03C32 Obsidian Black, '76Toyota Celica GT TRD, '12R350 4matic Arctic White, '06 ML 350 arctic white
Steve,
Just wanted to bump this thread.....I'm actualy wanting to post some type of mod for this but it's so limited. I do appreciate you starting this thread. ![]() John
__________________
![]() AMG Northeast member AMG Orphans Club International #87 CODE 3 Supercharger Pulley SL 55 Y pipe Dual CAI Johnson cm 30 pump Iso. Kit Secondary cat delete CF Trunk Lip 19" MMR GT-1 Clear HID 4300k projector fogs. |
#9 |
Thanks man! I try to remember to give this a bump every 2 weeks or so
__________________
#10 |
This should be a sticky!!! how do we do that?
__________________
#11 |
Good idea! I should reformat the first post to give it a cleaner set-up.
__________________
#12 |
Drives: Audi A4, 1982 Fiat Spyder, 2010 R350
#13 |
bump bump for readers and new ideas.
__________________
#14 |
Performance DRY air filter. So there is no oil to mess up with the mass air flow sensor.
AFE 30-10085 "Pro Dry S" Constructed with 100% polyurethane on all four sides, this high flow "oil-free" OE replacement performance filter will outflow stock paper filter for improved horsepower and torque. Two layers of progressively finer mesh synthetic media provide maximum convenience and easy maintenance. Washable and reusable for multiple cleaning cycles, the tall open evenly spaced pleats provide excellent dust holding capacity for longer service cycle between cleanings. Integrated urethane bump seal insures tight, no leak seal over the life of the filter. http://afepower.com/shop/details_new...rcedes&model=R Class&year=2006&engine=3.5L&&brandID=59
__________________
#15 |
TTT
__________________
#16 | |
Quote:
I strongly suggest getting the NON oiled air filters to prevent the oil from effecting the engine's sensors. I have direct experience with the K&N oil effecting my engine.
__________________
#17 |
Bump for new ideas
__________________
| Tags |
| 350, c350, camshafts, dynocomp, headers, kleemann, m272, mercedes, performance, r500, sport, super, tuning, v6, w272 |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Display Modes | Rate This Thread |
