Go Back   MBWorld.org Forums > Mercedes-Benz SUVs, Trucks, Vans, Diesels, Other > R-Class (W251)
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Members Insurance Search Today's Posts Mark Forums Read CarsGarageVendors
Welcome to MBWorld.org Forums
R-Class (W251) 2006-Present: R320CDI, R350, R420CDI, R500
LinkBack Thread Tools Search this Thread Rate Thread Display Modes
Old 07-13-2011, 06:56 AM   #1
Exclamation HELP - '06 R500 Suspension riding extremely high on one side
Our R500 is riding 6" or more higher on the driver side than the passenger side. The height is variable but will not ride level now so there is always a slight (and more often) extreme lift to one side. This happened for the first time a couple months or so ago and was a problem for a few days but the seemed to resolve itself so we figured maybe something had gotten stuck and after hitting a bump or something it was freed but it has now happened again and has been this way for a couple weeks. As far as I know we don't have "airmatic" (from what I've read it seems that if we did, we would have a manual switch to raise/lower the car but we don't seem to have that) but the car DOES raise/lower itself at times while driving (I've noticed it lowering after I've parked so something is being done automatically) and we do have a "C/S" switch that doesn't seem to do anything noticible. Anyone have this problem? The passenger side appears to be a fixed height while the driver side is adjusting higher and lower. Leaving on a 13hr each way road trip in a week and a half and hope to have this resolved by then.
To remove this ad, register today or login if you already are registered!
sksnumber1 is offline   Reply With Quote
Old 07-14-2011, 10:36 AM   #2
TINMan22's Avatar
Drives: 2007 R500
sksnumber1,
This is a new one! I pray that you have an extended warranty. I urge you to take it to the dealer, at least for a diagnosis. If you have an independent repair shop, they may be able to fix it for a lower cost than the dealer will charge.
JR
__________________
2002 C240
2003 C320
2005 SL500
2007 R500
2010 Volvo S80 T6 AWD
TINMan22 is offline   Reply With Quote
Old 07-17-2011, 09:18 PM   #3
Drives: 2006 R500 Red w/Tan interior
All R500's have an airbarg rear suspension, you only get the switch if the front suspension also has airbags, which I am guessing yours does not. I have an 06 R500 myself and had it into the dealer last week because on side was higher than the other -- but mine was just 1" off. My issue was a bent level sensor, apparently something had flown up from the road and bent something that the level sensor is attached to. Cost me 500.00 to have fixed. The part was $32 and the rest was labor, 4-wheel alignment that was needed. Your issue could be something else, best to pay to get it diagnosed by dealer and then decide to have them fix or someone else.
rgood10921 is offline   Reply With Quote
Old 10-12-2011, 09:04 PM   #4
Drives: S550
I have the same problem and my mechanic replaced the valve but did not solve the problem.
I asked them about the sensor but they did not know anything about it. Do you know the part number or better description so that I can get the part form the dealer to install.
I appreciate the help.
Sciling is offline   Reply With Quote
Old 10-18-2011, 01:38 PM   #5
Drives: r350
Same problem
I have an R350 and I have been having the same problem, sometimes it is fine and others not, I have noticed that when the tire pressure warning comes on this happens, don't know why.
Anyone?
apjdjd is offline   Reply With Quote
Old 04-01-2012, 12:33 PM   #6
joeboch348's Avatar
Drives: R350 X5 4.4 67 alpine
I'm having same problem. 1 day it's perfect, next day passenger side is 3-4 inches higher. Ugh. Any MB mechanics on this board?
joeboch348 is offline   Reply With Quote
Old 04-02-2012, 07:22 PM   #7
2006_MB_R500's Avatar
Drives: 2006 R500
Same problem here
I have a 2006 R500 without Airmatic and the rear driver side sags until the tire is almost touching the wheel well, while the rear passenger side is too high. It seems to be compensating for the sagging driver side. When you drive the car for a few minutes the driver side raises and passenger side lowers back to even. After driving sometimes it stays level and other times the driver side sags again. Oddly enough, it seems more pronounced after the tire pressure sensor goes off (I had a couple of nails in a tire). From all the reading I've done it appears to be either the ride height sensor, air bag or valve block. My regular mechanic fixed the tire and noted everything looked fine with the suspension, there were no leaks and the air bags seemed fine. He believes it's a sensor. I'll find out more when it goes to the dealer on Thursday. I can post the diagnosis and repair estimate if anyone is interested (though I won't be having the dealer perform the repair. I get the parts from the U.S. at 25% of the price they charge us in Canada).
2006_MB_R500 is offline   Reply With Quote
Old 04-02-2012, 07:34 PM   #8
joeboch348's Avatar
Thanks. Please do let me know. Its the exact same thing i have going on except the low tire. My car is going in tomorrow tuesday to my indy repair shop. Maybe he can figure it out. Until then i tell my friends it lowers to let you in like a citreon ha ha
Old 04-02-2012, 07:36 PM   #9
Drives: 2006 R500
Haha, good cover. No problem, I'll post the cause and estimate on Thursday evening. My indy mechanic couldn't tell the exact problem, he said it has to go to the dealer for diagnosis. Good luck tomorrow!
Old 04-02-2012, 08:48 PM   #10
joeboch348's Avatar
I also belong to XOUTPOST.COM. For my x5. There are a bunch of dealer mechanics on there with answers. Seems on this board were on our own
Old 04-02-2012, 08:50 PM   #11
Drives: 2006 R500
It does appear that way, but a few MB mechanics answer posts on Benz World.
Old 04-03-2012, 01:49 PM   #12
joeboch348's Avatar
My guy couldnt do anything without the mb computer
Old 04-03-2012, 02:26 PM   #13
Drives: 2006 R500
Yep, that's what my guy said too. Mine seems to be slanting further to the driver side as of today. First pic is the rear passenger side, second is rear driver side. Notice the large difference in space between the top of the tires and the fenders. The pic from the front speaks for itself lol.
HELP - '06 R500 Suspension riding extremely high on one side-img00045.jpg   HELP - '06 R500 Suspension riding extremely high on one side-img00046.jpg   HELP - '06 R500 Suspension riding extremely high on one side-img00047.jpg
Old 04-03-2012, 03:21 PM   #14
joeboch348's Avatar
Found another indy that is strictly german. Going in tomorrow
Old 04-04-2012, 08:22 AM   #15
Drives: 2006 R500
If they specialize in German cars they should be able to diagnose it. Please let me know what they say. I saw the DIY regarding conversion of the air system to coil. If the air system is going to be nothing but trouble it may be worth looking into.
Old 04-04-2012, 05:20 PM   #16
joeboch348's Avatar
Just got the call. $700 to replace the drivers side air bag. Said 100% thats the problem so i gotta bite the bullet
Old 04-04-2012, 05:21 PM   #17
Drives: 2006 R500
Interesting. You can get a pair from Arnott for $299.
Old 04-04-2012, 06:53 PM   #18
Drives: 2006 R350
Send a message via Skype™ to aljajoly
You can change the level sensors, $130 each side P/N W0133-1830313, or $70 P/N REPM289701Canada Parts Online. very easy, 3 10mm screws behind the air bags, 30 min. job each side.
It may be your air bags as well, they last only 70k miles. You can get a pair from Arnott for $299. 1 hour job each side.
Hope this helps.
aljajoly is offline   Reply With Quote
Old 04-04-2012, 07:08 PM   #19
joeboch348's Avatar
Up i know guy says you need the computer so um handcuffed. 1st time using this guy
Old 04-04-2012, 07:15 PM   #20
Drives: 2006 R500
Aljajoly - Thanks for letting me know about Canadapartsonline, they have a lot of parts at good prices. The sensor price is the lowest I've encountered.
Joeboch - That's interesting. I'm surprised they need the computer because I have read a couple of DIY write ups on changing the bags and it doesn't look complicated, nor was there talk of the computer. As long as it fixes the problem, that's what counts.
I'm curious to hear what the dealer finds with mine tomorrow.
Old 04-04-2012, 07:52 PM   #21
Drives: 2006 R350
No computer required guys, I changed it al myself and everything works fine.
Old 04-04-2012, 07:54 PM   #22
Drives: 2006 R350
Once everything has been installed you must go on the highway and ride at 70 mph's for about 10 minutes and the onboard computer will set everything perfectly.
Old 04-04-2012, 08:00 PM   #23
Drives: 2006 R500
That's interesting. I read the DIY writeup here:
http://www.benzworld.org/forums/w251...n-air-bag.html
Doesn't seem too difficult, but I'd still have my indy mechanic do the replacement. I know where my strengths lie, and unless it's very simplistic, auto mechanics is not my forte
Old 04-04-2012, 09:31 PM   #24
joeboch348's Avatar
I probably got taken for a few hundred. My wife is driving my X5 today while her R is in the garage. I want hers fixed before she scrapes my chrome wheels on a curb ir spills a mocachino all over the interior haha
Old 04-04-2012, 09:34 PM   #25
Drives: 2006 R500
Actually he is probably getting the part from the dealer, so with labor $700 is probably bang on the going rate. I'm sure your wife appreciates your efforts
Tags
airmatic, benz, collapse, front, high, leaning, low, lower, mercedes, r350, r500, rear, side, stuck, suspension
Search this Thread:
Advanced Search
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Copyright © 2001-2012 InternetBrands, Inc. / MBWorld.org. All Rights Reserved.
Everyone's Personal Details
SEO by vBSEO 3.5.2
