Sign in using an external account
| R-Class (W251) 2006-Present: R320CDI, R350, R420CDI, R500 |
LinkBack | Thread Tools | Search this Thread | Rate Thread | Display Modes |
#1 | ||
Drives: c220 cdi Elegance & R320cdi-L V251
Headlight wires?
#2 |
Drives: 08 R350, 07 Acura RL, 1989 Honda Shadow VLX600 (10K miles)
Connect Positive DRLs to the Relay (87)
Positive batery terminal to Relay (30) The park light positive to the relay(86). Ground negative relay(85) to chassis and DRLs to chassis ground. When you turn on the exterior light or head lights, the DRLs will be on.
__________________
2008 Black Mercedes R350 w/P1 package/Ipod/Heated seats/7 seats, 10.2" Overhead LCD monitor w/ DVD player hard wired into factory sound system, B/U camera integrated W/6 Disc DVD Changer, Retrofitted OEM GPS Navigation, Passport Escort X8500 hardwired, Mtec HID, 17 SMD LEDs city lights. 2007 Acura RL w/Tech. package.(TVandNAV2go ,USA-spec audio, A-Spec body kit, 18 " Wheels, Wooden Steering Wheel, Wooden Shift Knob.. Last edited by AsianR350; 07-17-2011 at 09:27 AM. |
#3 |
Thanks for your reply.
The DRLs im getting have a function that flashes with the turn indicators, hence why i also need to connect to the indicators. Here's a clip of its functions. http://www.youtube.com/watch?v=d8YKCTiw3io |
#4 | |
Quote:
One for left and one for right turn signal or get a turn signal relay for left & right.
__________________
2008 Black Mercedes R350 w/P1 package/Ipod/Heated seats/7 seats, 10.2" Overhead LCD monitor w/ DVD player hard wired into factory sound system, B/U camera integrated W/6 Disc DVD Changer, Retrofitted OEM GPS Navigation, Passport Escort X8500 hardwired, Mtec HID, 17 SMD LEDs city lights. 2007 Acura RL w/Tech. package.(TVandNAV2go ,USA-spec audio, A-Spec body kit, 18 " Wheels, Wooden Steering Wheel, Wooden Shift Knob.. |
#5 |
#6 |
Hi,
my kit has arrived and im trying to find remaining places to tap into In addition to the info from AsianR350 Connect Positive DRLs to the Relay (87) Positive batery terminal to Relay (30) The park light positive to the relay(86). Ground negative relay(85) to chassis and DRLs to chassis ground. I still need to find a true positive source to power the DRLs. The DRLs are rated at 6W each. So im not sure i can use the Relay87 to supply the power rather than just a signal. Shouldnt be hard to locate a suitable earth. Which is the Turn signal relay? And would there be any issues using a piggy back spade connector with these relays? |
| Tags |
| 2011, battery, benz, drl, fuse, headlight, installation, led, light, mercedes, negative, positive, r350, r500, w251, wires |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Display Modes | Rate This Thread |
