Steering Column Power Tilt Issue
2002 E430 Sport
The power tilt function on my steering wheel is not working but the power telescoping function is still working. I called the dealership to see if the motor that controls the tilt can be replaced and they said the entire column must be replaced at a cost of $1700 plus labor!
Please help with the following questions:
Has anyone had this problem?
Is this a recall or TSB that could be fixed by the dealer for free?
Could the issue be a bad fuse/relay/module?
If the column must be replaced, would it be okay to by a used one?
Is this a DIY job?
Thanks for the support and advice!
Is this a DIY job?
I had a problem similar to this and a connection had just become loose. Might want to have an independent take a look at it first.
