Took R350 To Carmax
Thanks for your reply not_too_shabby
there's only 1 code (P0015). read online there's a toyota TSB regarding this code. the TSB says it could be due to sticky valve lifters and to add a bottle of EFI cleaner & run the engine till the CEL goes off.
so, I got a 5oz bottle of Lucus fuel injector cleaner & lubrication from walmart. drove the car to work this morning with the CEL still on. poured the bottle of Lucus in the gas tank before driving home after work. had the engine started while i clear the off the snow & walaa.....the CEL is off....
will check again when i drive to wokr tomorrow morning. hopefully the CEL stays off....
There isn't. There is a class action suite settlement.
Here is one site regarding it.
http://topclassactions.com/lawsuit-s...nary-approval/
May be wise to print it out and discuss with your dealer..
Sprocket worn out premature dues to the softer material that supplied by vendor and also his problem (P0015)Magnet – Camshaft Adjustment Camshaft.
Or you could do this: https://mbworld.org/forums/r-class-w...r-r-class.html
