08 R350 Right Mirror Turn Signal problem
2008 R350 4Matic
I was getting an intermittent "Turn Signal Right Mirror" error. At times the led signal would light even with the error. Within a couple of weeks I got a constant error and the led signal quit altogether. I ordered a new MB led unit and replaced it, with no luck. Left side works normally and the right front and rear work fine. Of course I get the rapid console indication when the right is on.
Looking at the WIS data, it appeared to me that the most logical culprit was the Right Front Door Control module. I replaced mine with a "certified working" used part from a dismantler removed from an 2006 R350. Same symptoms. I could really use some help with this.
It could be a bad wire. Test the leads to see if they're all working. If this is outside your confidence range, take it to an automotive electrician.
