55W - 5500K Morimoto Elite HID installed
OEM modified H7 bulb holders with 55W - 5500K HID lights.
No error waring.
No error waring.
35 watts HID fog lights with LED amber city lights
Nice work AR350 My Kensun kit made me have to use one of those 3rd party open clips and oMG it was painful...
I do know what the inside of my headlight housing and the H7 housing looks like now though, all by touch
I am thinking I should have gone 6k to better match my drl (yet another set I had to try but these ones are a keeper) but I can't be bothered to get back into the housing atm...
Btw, did you mount the ballast outside or inside the housing? I have everything (including cancellers) inside and I've been checking the plastics quite often and everything holding up perfect.
55w Kensun Kit
JonMac - I installed the Kensun Kit also, for low beam. I put the ballast and warning signal outside of the housing and zipped tied at this time. I re-used the OEM bulb retaining clip by cutting one corner and taping it to the H7 bulb holder. Working good, so far.
Cheers I ended up buying aftermarket clips because I wanted to keep the originals intact but those clips I had to modify (butcher) to get them to lock in properly! But it's all working well now for the past couple of weeks
I had installed the ballast and ignitor inside the housing and no problem with the heat issue.
