ABS/ESP warning message after install aftermarket HID light.
If you just install the aftermarket HID lights and ABS/ESP warning message error shows on your MID, your wheel speed sensor is not at fault. Your HID ballast causes EMI that trigger the message because the ballast is mounted near the ABS module.
What I did was put everything (HID) inside the headlight housing and the message went away. You can move the ballast away from the ABS module or wrap the HID harness with aluminum foil.
