R-Class (W251) Produced 2006-2013: R320CDI, R350, R420CDI, R500
Bluetooth function and audio!
Old 01-24-2017, 05:45 PM
irvinvali's Avatar
R350, SEL 450, SL 450, C230
Question Bluetooth function and audio!
So my only issue with my 2010 R350 which I recently purchased is that for some reason I cannot get any audio on my Bluetooth other than the phone, so no music playing on the iPhone will broadcast through the Bluetooth! Is that normal? is it just an older Bluetooth system?
Old 01-25-2017, 12:46 PM
CedarMtn's Avatar
2011 R350 BT
It's an older system, so no Bluetooth connection for anything except the phone function.
There might be some way to hack a fix to this, as iPhone navigation using Maps will broadcast the voice commands through the speakers (using bluetooth) and Siri works via the speakers too for paired iPhones. You lose the navigation map when this happens. I have the iPod connector in the glovebox - this is the old style connector and I have an old iPod Classic which is my car's music library. It does work with a lightning adapter too.
The following 2 users liked this post by CedarMtn:
hvacdude (11-14-2022), irvinvali (01-25-2017)
Old 01-27-2017, 10:36 AM
dinfung's Avatar
2013 R350
As CedarMtn said is just an old system. I also have an iPod classic plugged in the glove box. 160gb of music!
Old 01-27-2017, 01:50 PM
fabbrisd1's Avatar
Received 1,098 Likes on 805 Posts
A gaggle of MB's
Well... if you have Media Interface port in your R350 - then you can use this cable/dongle to add Bluetooth Music:
https://www.amazon.com/Bovee-WMA3000...edia+connector
The following 2 users liked this post by fabbrisd1:
hvacdude (11-14-2022), irvinvali (01-27-2017)
Old 01-27-2017, 05:48 PM
irvinvali's Avatar
That is great. I actually do have the cables in the gloves box and so you are saying I just add this and replace with the old one! I am willing to spend 90 bucks if it resolves my issue.
I ordered this which I believe is a match and compatible with my R class.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Thanks again.
Old 01-30-2017, 10:38 PM
Onnzo's Avatar
C63 / E400 Cab
Hi all - for those that have this, does it allow the phone function on the device to work normally whilst playing music?
Can you still use the steering wheel to answer/hangup?
Old 01-31-2017, 10:29 AM
irvinvali's Avatar
you mean with the WMA3000A Bluetooth Adapter? I have not put mine on but I would think you can. I'll check it out and let you know by tomorrow.
Old 01-31-2017, 04:28 PM
Onnzo's Avatar
C63 / E400 Cab
Thanks. Yes I do mean with the Bluetooth adaptor.
Old 02-02-2017, 07:52 PM
irvinvali's Avatar
So I got the adopter and connected my iPhone 6s to it, however, the audio music function still does not work but the phone of course does connect. a small headphone icon appears on the phone when connected to the device and I cannot figure out why it does not play music out of my phone.
Any ideas?
Onnzu, the phone does disconnect via the steering wheel even after connecting it to the adapter, if that was your question.
Old 02-02-2017, 09:17 PM
Onnzo's Avatar
C63 / E400 Cab
Thanks for checking. Your post says it does disconnect. Do you mean it does connect?
check to see if you have the option to play music via the headphones/adaptor or speaker. Swipe up from the bottom to bring up the control Centre (and right on the latest iOS which has a separate control Centre for audio)
ive already ordered mine so I'll see if I have the same problem when it arrives
Old 02-03-2017, 08:29 AM
irvinvali's Avatar
oh okay sry no I meant to say that from what I can tell so far, although I cannot play music through the adapter, I am able to hang up and answer calls via the steering wheel when the adapter is connected to my iPhone.
please tell me what your experience with this is as I am concerned that this is not a match for my 2010 system and I may have to return it and get another one that is compatible, if I am having an issue of compatibility.
As far as what you were saying I should try on my cellphone, are you suggesting I should change something on my settings on my cell in order to be able to play what is on the cellphone through the adapter?
Again, please keep me posted on your experience once yours arrive.
Old 02-04-2017, 01:14 PM
irvinvali's Avatar
So okay i got it to work and it works perfectly. I had to "forget this device" on the car Bluetooth and then connect to the adapter. Everything works including the hang up/ call button on the steering whern 🍻
Old 02-05-2017, 05:57 AM
Onnzo's Avatar
C63 / E400 Cab
That's great to hear. My unit is still being shipped. Will probably be another 1-2 weeks
Old 02-08-2017, 04:15 PM
irvinvali's Avatar
mine was fine but for some reason it no longer works since two days ago. I only see a headphone symbol on my phone and no audio from the phone is transmitted to the car!! I mean the unit seems okay but some how my car does not connect to my phone, although the phone is connected to the phone and of course plugged in where it should be!
Old 02-09-2017, 02:55 PM
olimar814's Avatar
2010 r350 bluetec 4matic
Amazon Amazon
66 at amazon
Old 02-09-2017, 09:41 PM
irvinvali's Avatar
^ya that is exactly what I got...I got them to work but it is complicated...apparently I-tune activates it and otherwise, it does not work!!
Old 02-15-2017, 06:05 AM
Onnzo's Avatar
C63 / E400 Cab
My delivery arrived today and I plugged it in and synced. It worked first go. I did notice that the car was paired to my wife's phone and music was connected to my phone at the same time.
Not it sure how that is going to work when calls come in. Presumably it will prioritize the phone connection over music.
Edit - been using it for a few days now. Its great and music starts playing as soon as I get in the car from where it left off. Taking calls works as normal and I can control the songs from the steering wheel.
Money well spent!
Old 03-16-2017, 11:59 AM
bensitto's Avatar
S550, R350, GL550, ML63 AMG
Exclamation
Your bluetooth audio should work on that COMAND head unit. When all else fails, Youtube it. The pairing is more difficult than it should be.
GL.
Old 03-22-2017, 03:51 PM
mtarq's Avatar
2008 Mercedes-Benz R320CDI 4Matic
I just bought a pre-owned 2008 R320 model, a Bluetooth device is installed under the armrest, when I start the car this device flash with blue light and on from monitor I get the message that "Phone is being activated, please wait", but after some time device flash stop and i get message that "Phone off".
While the device flash, I pressed the Star logo button for long but device never flashed quick, and my mobile never found the car Bluetooth for pairing.
How can I delete all the data for old paired devices ?
or How I confirm that my Bluetooth device is OK?
Old 11-14-2022, 12:10 PM
hujirong's Avatar
R350 Bluetec
Does this support phones other than iphone? I have a 2013 R350 and this problem has bothered me a long time.
Old 12-07-2022, 08:01 PM
efzauner's Avatar
2005 C240 2011 R350
talk about resurrecting Ye Olde Thread.
Yes, it supports any BT phone.
Your newer post face lift R350 has bluetooth for phone. I gather you are using it. It does not support bluetooth audio. This is mentioned in your owners manual or the Command manual. Use the aux audio input, or what I do, I have put my music on an SD card. Much better audio quality than BT.
Quick Reply: Bluetooth function and audio!
