Go Back   MBWorld.org Forums > Mercedes-Benz Coupes & Cabriolets > S/CL-Class (W140) Coupe
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Members Insurance Search Today's Posts Mark Forums Read CarsGarageVendors
Welcome to MBWorld.org Forums
S/CL-Class (W140) Coupe 1994-1999: S500 Coupe, S600 Coupe, CL500 Coupe, CL600 Coupe
LinkBack Thread Tools Search this Thread Rate Thread Display Modes
Old 10-08-2006, 08:47 PM   #1
Drives: a car that confirms all your prejudices
Opening the bonnet / popping the hood
... as I believe Americans call it..
For the first time, I need to get into the engine in my 600. Every Merc I've had or dealt with in the past has been a W123 or W124. You pull a handle inside the car, and then another handle pops out of the grille, and the bonnet/hood opens slightly. Then you pull the handle sticking out of the grille, and everything opens. I'd assumed it would be the same with this car.
But this time, when I pulled the handle inside the car, nothing popped out from the grille. I felt around underneath and couldn't find a handle or anything. Should there be one (in which case it's broken off), or is there a different way to open W140 coupe bonnets/hoods? If there's suppposed to be a handle popping out of the grille and it's broken, how do I get in?
To remove this ad, register today or login if you already are registered!
hkmb is offline   Reply With Quote
Old 10-09-2006, 07:05 PM   #2
Pull the hood release from inside the the vehicle. From the ouside, stick your hand into the large Mercedes Star and pull on the release. Voila!
__________________
JUNIORGEN
1998 S420
1997 S500 Coupe sold
1979 450 SLC sold
2001 E430 4MATIC sold
jgen is offline   Reply With Quote
Old 10-18-2006, 01:24 AM   #3
Ahha! I shall try that when I get home tonight. Thank you!
Tags
190e, benz, bonnet, brok, cable, cl600, hood, hoodbonnet, open, openet, opening, popping, w123, w140, w202
Search this Thread:
Advanced Search
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
cable for opening bonnet murphe5 C-Class (W202) 4 07-28-2006 02:35 AM
Close Hood / Bonnet Error Code Motzkoman SLK-Class (R171) 4 06-09-2005 02:28 AM
Trouble Popping the Hood jballou 190E (W201) 5 11-23-2004 02:55 PM
Copyright © 2001-2012 InternetBrands, Inc. / MBWorld.org. All Rights Reserved.
Everyone's Personal Details
SEO by vBSEO 3.5.2
