Go Back   MBWorld.org Forums > Mercedes-Benz Coupes & Cabriolets > S/CL-Class (W140) Coupe
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Members Insurance Search Today's Posts Mark Forums Read CarsGarageVendors
Welcome to MBWorld.org Forums
S/CL-Class (W140) Coupe 1994-1999: S500 Coupe, S600 Coupe, CL500 Coupe, CL600 Coupe
LinkBack Thread Tools Search this Thread Rating: Thread Rating: 2 votes, 5.00 average. Display Modes
Old 11-14-2010, 10:57 AM   #1
Drives: S 420
Fuse #21 blows as soon as the car is started - 1998 S420
Fuse #21 (20 Ampers) located in fuse panel located in the engine compartment near the brake fluid resevoir blows as soon as I start my 1998 S420. Some additional information that may be related as the following:
1. Fuse #21 blows every time I start the car. The things listed against that fuse are automatic climate control, outside mirrors heating, transmission oil cooler and heater wiper. I tried turning off the A/C and then replaced fuse #21 and re-started the car and that fuse still blows as soon as the car is started. I also disconnected the blower motor and blower regulator and started the car and fuse still blows. I try a 25A fuse (instead the 20A) and same problem.
2. The A/C fan is currently only running at one speed which is very low regardless of the settings inside the car. I have not replaced the blower regulator yet which is normally the source of this particular issue because I don't understand the issue with fuse #21 which keeps blowing.
I hope someone can help,
To remove this ad, register today or login if you already are registered!
jorios is offline   Reply With Quote
Old 12-03-2010, 03:07 PM   #2
I could be the mirror heater. My 97 had some cracked insulation on the wiring in the mirror which shorted out. Gave me fits until it "smoked checked" one day.
Cheers,
Steve
__________________
1992 300CE 150K
1997 S500 Coupe 47K
SteveUrban is offline   Reply With Quote
Old 12-22-2010, 05:51 PM   #3
Drives: S 420
I just want to share the solution to the problem in case someone else is having this issue. I changed the blower regulator and that fixed the air conditioning and the issue with fuse #21. The old regulator was faulty causing all these problems. Now the AC works great and fuse #21 is OK too.
Tags
1994, 1998, 21, blower, blowing, coupe, disabling, fuse, fuses, mercedes, pics, regulator, s420, s500, w140, wiper, wipers
Search this Thread:
Advanced Search
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Copyright © 2001-2012 InternetBrands, Inc. / MBWorld.org. All Rights Reserved.
Everyone's Personal Details
SEO by vBSEO 3.5.2
