S/CL-Class (W140) Coupe 1994-1999: S500 Coupe, S600 Coupe, CL500 Coupe, CL600 Coupe
Mileometer display problem
Old 01-16-2013, 06:23 AM
merc350sl's Avatar
sl350
I have a mercedes 350 sl a strange pink squiggle has appeared in the mileometer display behind the mileage figures. Any ideas?
Old 01-16-2013, 11:09 AM
cal1's Avatar
SL55, ML500 & Acura TL
Strange indeed. Have you tried scrolling through the display options to see if the squigglies clear?
Old 01-16-2013, 11:27 AM
merc350sl's Avatar
sl350
Thanks for the suggestion, i have tried every display option but to no effect. I'm wondering if anyone out there has had the same or similar problem, i think it may be weather related. I've had the usual boot leaking issues which i believe are common on sl's.
Old 01-16-2013, 12:05 PM
cal1's Avatar
Are you thinking maybe cold or moisture is causing it? If so it might resolve itself. My SL sits in the garage all winter so it does not see the cold.
The leaky boot is common to the R230. Here is a link to some good discussion on the issue: https://mbworld.org/forums/sl-class-...runk-leak.html
Old 01-16-2013, 12:09 PM
merc350sl's Avatar
sl350
Cheers. Might wait a while for some warmer weather though!
Old 12-05-2016, 06:07 PM
dsturman's Avatar
E53 AMG 2019
Same here
I have the exact same problem but it is on the temperature readout. It has gotten worse and worse as time goes on. Help.
Quick Reply: Mileometer display problem
