Go Back   MBWorld.org Forums > Mercedes-Benz Sedans > S-Class (W116)
Sign in using an external account
Register Forgot Password?
Home Register Photos FAQ Members Insurance Search Today's Posts Mark Forums Read CarsGarageVendors TSB & Recalls
S-Class (W116) 1972-1980: 280S, 280SE, 280SEL, 350SE, 350 SEL, 450 SE, 450 SEL, 450 SEL 6.9, 300 SD
Welcome to MBWorld.org Forums
submit to reddit
LinkBack Thread Tools Search this Thread Rate Thread Display Modes
Old 10-28-2009, 05:35 PM   #1
Hercules86's Avatar
Drives: Sclass
rain inside the car???
hi i pruchased a mint condition 300sd a while back.. the original owner had it for close to 30 years since its a 1980 and he only drove it about 5000 miles a year.
i have brought the car to the wash numerous times with no water ever coming inside the car.
lately in ny its been raining the past couple days and when i came to my car this morning the driver rear seat and passenger rear seat floor pans were full with water. About 2inch on driver rear seat side and 1/2 inch on passenger rear seat side.
i drilled two drain holes in the back corners of the floor panel and the water immedietely evactuated.. Since then there has been little water buildup but there is still water coming into the car alitte at a time. If i look at the seat belt pillars toward the bottom of the floor the carpet is only wet in that little spot on both sides. Is that where the water is originating from? The rubber door seals are dryed out and cracked somewhat on both sides. is that the problem? because in the drivers seat floor pan and passenger side floor pan theres no water at all. The back rear windsheild gets foggy somewhat also when it raining when the cars parked? does this mean the rubber seals all need to be replaced?
To remove this ad, register today or login if you already are registered!
Hercules86 is offline   Reply With Quote
Old 10-28-2009, 07:04 PM   #2
C43AMG's Avatar
Drives: 98 Black C43 , 00' C230K , 91 420SEL , 08' ML320 CDI
Check the drain holes in your sunroof
__________________
No engine , no badge
C43AMG is offline   Reply With Quote
Old 12-28-2010, 04:58 AM   #3
WGB
WGB's Avatar
Drives: W212 E500, W164 320CDI, W116 450SEL 6.9, W116 450 SEL.
Quote:
Or rust around the front drain holes of your sunroof frame or your bulkhead particularly beneath the master cylinder/fusebox area.
The front sunroof drains can be seen about half way up front door hinge area at the front door leading edge and are visible as rubber tubes protruding when the doors are wide open.
Either compressed air or careful use with string trimmer line will clear them.
Bill
WGB is offline   Reply With Quote
Old 05-24-2011, 08:56 PM   #4
Drives: 1980 300SD
Probably your sunroof drains are clogged or you have a windscreen leak.
Probably you want to replace all the rubber stuff - it just doesn't hold up for 30+ years very well. I'm looking at replacing the front/rear windscreen gaskets, the door seals, the window trim, the sunroof seals, the seals around the rear taillights, a seal on the power antenna, and also some other rubber parts I've spotted in not-so-great shape. About $1500 to do it all with OEM parts, plus probably around $150 to have the windscreen replaced by somebody more competent than myself. I figure it's a bit pricey but a good investment for the next 30 years, as I intend on keeping this car running that long.
Raptelan is offline   Reply With Quote
Old 05-26-2011, 03:36 AM   #5
Drives: 2001, MZ
Might try a box/window fan(s) when in the garage. We use them on occasion when our basement floods. A little musty smelling at first but dries fine after several days.
__________________
mercedes headlights
roseann is offline   Reply With Quote
Old 01-25-2012, 12:31 AM   #6
Drives: moter bike
So nice to visit here its really a nice thread. good hard work, you are doing good work good luck, keep it up..
John Stewe is offline   Reply With Quote
Old 03-22-2012, 08:05 AM   #7
Drives: 1200
Fogging or freezing on the inside of the car is most easily solved by the
following
1) Use a (inside) glass cleaner like Windex, and clean the glass so it's
spotless
(Remember to really buff it with a dry towel -it's an important
step)
Clean glass on the inside is a MUST to reduce the risk of
condensation.
2) When you get into a cold car, crack a back window open and start up
your fan on defrost to start air moving on the inside of the windshield as
well as the cabin. Try to leave your door open till until after you have
started the motor and cranked up the fan.
Keep this up until you are getting warm air, at which point you can
start shifting where the air is sent
You are generating humid air by breathing and it will automatically
hit the glass as condensation. The open window lets out warm moist air, and
lets in cooler dryer air.
3) If you have tracked snow or rain into the car, keep the air moving and
the window cracked to reduce the risk of condensation, until the water has
been eliminated
__________________
Towing Sydney
JamniaArce is offline   Reply With Quote
MBWorld
Mercedes SLR McLaren
Paid Advertisement
submit to reddit
Tags
back, bottom, car, coming, console, door, floor, inside, mercedes, photo, rain, rained, raining, seat, water
Search this Thread:
Advanced Search
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Advertise on MBWorld - Contact Us - MBWorld.org Forums - Archive - Top
Advertise on MBWorld.org - Terms of Service - Privacy Policy - Jobs
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2
Copyright © 2001-2011 InternetBrands, Inc. / MBWorld.org. All Rights Reserved.
Everyone's Personal Details
