You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
I'm on the last leg of my rebuild and hooking up trans wires, green to kick-down solenoid and the other brown and black back to pressure sensor on back of tranny. Does anyone know if the green wire going to the Kd soleniod is supposed to be hot with key in the run possition, on all the time seems od, I have checked the Kd switch under the pedal and no power at either wire, it seems to be a on off type system but not familiar if it is controlled by the box on pass side kick panel. some thoughts on how it works, thanks in advance in Alaska not much knowledge here
To remove this ad, register today or login if you already are registered!
