S-Class (W126) 1979-1991: 300 SE, 300 SEL, 380 SE, 380 SEL, 420 SEL, 500 SEL, 560 SEL, 360 SEC, 500 SEC, 580 SEC, 300 SD TURBODIESEL, 300 SDL TURBO, 350 SD TURBO, 350 SDL TURBO
1990 350 SDL (126) rotary switch removal
Old 03-03-2005, 03:32 PM
gene_pool41's Avatar
I'm trying to replace the headlight rotary switch in my 1990 350 SDL. Easy enough to loosen, twist, and detatch the switch from the dash, and then remove the panel immediately underneath the instrument cluster hoping to access the back of the switch.
No clue how to remove the tubular corregated heater ducting running the length of the driver's side (hidden by the panel just removed) to gain access to the back of the switch for removal. I could not find a procedure for this in my big gray official "shop" MB manuals for the 126.
Any suggestions on how to remove the heater ducting?
Thx in advance!
Old 03-13-2005, 04:18 AM
farooq's Avatar
560SEL
use a chain saw!! haahahh.. :p
Quick Reply: 1990 350 SDL (126) rotary switch removal
