Go Back   MBWorld.org Forums > Mercedes-Benz Sedans > S-Class (W126)
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Members Insurance Search Today's Posts Mark Forums Read CarsGarageVendors
Welcome to MBWorld.org Forums
S-Class (W126) 1979-1991: 300 SE, 300 SEL, 380 SE, 380 SEL, 420 SEL, 500 SEL, 560 SEL, 360 SEC, 500 SEC, 580 SEC, 300 SD TURBODIESEL, 300 SDL TURBO, 350 SD TURBO, 350 SDL TURBO
LinkBack Thread Tools Search this Thread Rate Thread Display Modes
Old 06-15-2009, 11:07 PM   #1
Drives: 300D
350SDL 6-cylinder diesel: not as good as the older 5-cylinders?
I just heard an interesting comment about the quality of diesel engines.
The newer 126 8-cylinder engines have many more troubles than the older 5-cylinder engines.
What's your take on this?
To remove this ad, register today or login if you already are registered!
Benzdom is offline   Reply With Quote
Old 06-16-2009, 02:57 PM   #2
Drives: 09' E320
The 3.5L diesel was a 6 cyl which has come to be known as the "rod bender". Said to have been the worst engine MB has made.
It was used in later W126 SDL's and all W140 300SD's and S350's from 90(?) up through 95. Some of the later long block crate replacement motors were said to have used updated rods. Some of them apparently failed too
The 5 & 6 cyl 3.0L diesels (eg: 617's, 602's & 603's) have all proven very reliable as has the 606 family.
__________________
T. Allison
85' 300D 311k miles
99' E300 311.5k miles (totaled)
09' E320 Bluetec 66k
TMAllison is offline   Reply With Quote
Old 06-16-2009, 03:28 PM   #3
Drives: 300D
Thank you, TMAllision.
I'm currently considering either buying a 2000 C230 or an older Turbodiesel.
Considering the economy, the turbodiesel would probably the saver bet.
Your valuable info is very much appreciated.
Old 06-25-2009, 03:26 PM   #4
Drives: 1987 SDL; 2001 Chevy 2500HD CC, 8.1L, Allison special order; 1970 GTO LS2, 4L60E, under construction
The updated motors used a new block that allowed the cylinders to stay round. That's what bent the rods....
Best 6 banger combo is the 3.5L with the replacement block. Second best is the 3L 6 in any form.
And to answer your question, the 6 bangers' are worlds better than the 5 cylinder timing chain eaters.
__________________
2x Grand Champion
Goatman is offline   Reply With Quote
Old 06-26-2009, 08:09 PM   #5
POS
POS's Avatar
Drives: 1966 250SE Cab, 1985 500SE Euro, 1985 190e 2.3-16 AMG, 1986 300E LeMons Car
You'll get better mpg out of a modernish 6-cyl MB gas engine than you will an older TD.
__________________
1994 w124 E320 wagon
1985 w201 190E 2.3-16v AMG
1986 w124 300E LeMons race car
1971 w109 300SEL 6.3 vintage race car
POS is offline   Reply With Quote
Old 06-26-2009, 10:09 PM   #6
Drives: 300D
I found that out.
I must really say I'm very much in favor of buying a 2000 or so E-class.
As much as I like my old 300D, I'm in the mood for some smooth power and speed.
Old 06-27-2009, 01:58 PM   #7
Driving an S-class TD vs the old 300D's is like driving a Volvo and calling it a MB... No comparison. I was looking for a 300D untill I drove an SDL. Then I had to have one.
__________________
2x Grand Champion
Old 06-27-2009, 05:04 PM   #8
Drives: 09' E320
Like the SDL, tuna boats also wallow when manuevering aggressively and are underpowered for thier size.
Newer vs older tech (if one can afford it) is usually a no brainer.
__________________
T. Allison
85' 300D 311k miles
Old 06-28-2009, 07:02 AM   #9
Plenty of power on the SDL, you must be thinking of the 300D's...
__________________
2x Grand Champion
Old 06-28-2009, 07:30 AM   #10
Drives: 1982 300D VNT, 1980 240D 3.0T, 1982 300TD
Quote:
I think you mean 6-cylinder, and yes, its true.
Early 3.0L engines were prone to cracking the head if allowed to get too hot.
All 3.5L engines are at risk for bending rods. It was a poor engine design and MB never officially acknowledged there was even a problem.
The 3.0L is a great engine if combined with a later head casting (#17-22), ironically, from the 3.5L.
240D 3.0T is offline   Reply With Quote
Old 07-19-2009, 08:34 PM   #11
Drives: 1994 SL500 E320
bgbrown125
Send a message via Yahoo to bgbrown125
350SD
I have one of the good ones. My 1991 350SD has 242600 miles on it and will still haul #$@! I've owned it for about eight years and it has been and still is one awesome car.
The engine failures that you speak of usually occur fairly early in life IF they are going to occur. Statiscally, less than 50% of the engines ever fail. Granted that is a high probability of failure. "All" is not a fair word.
bgbrown125 is offline   Reply With Quote
Old 07-29-2011, 05:58 AM   #12
The problem should be contributed to a factor other than a faulty design by MB if ALL engines are not affected.
Any thoughts on this?
kayooh is offline   Reply With Quote
Old 08-03-2011, 06:49 PM   #13
oldsinner111's Avatar
Drives: s320 and 300sd
nate rector
could have been a metalurgy problem also.When I was a Machinist,some of our bearing races grew .030.
__________________
1999 S320 plus 125 nitrous shot hp,modified grille area,and cold air intake,wrapped exhaust manifold,wrapped air duct,cold air,ceramic pads,no cats
Borla exhaust one muffler14.4 1/4 mile 1983 300 SD not stock Mobil One ATF diesel rated oil both cars
oldsinner111 is offline   Reply With Quote
Old 08-19-2011, 08:20 PM   #14
Drives: 300SDL; E300D
Quote:
300sdl is no doubt powerful, quiet and smooth.
sdlcrazier is offline   Reply With Quote
Old 03-13-2012, 03:58 PM   #15
bgbrown125
I've heard the same "bad" issues with the 350SD. HOWEVER, I had a 1991 350SD for over a decade and sold it a couple of years ago with 275000 miles on her. She would fly and I never had any motor issues with her at all. Great Car! Some of them did have issues...I had a good one!
350SDL 6-cylinder diesel: not as good as the older 5-cylinders?-101_2161.jpg
Tags
300d, 350, 350sdl, 6, 603, bender, benz, cyl, cylinder, diesel, engine, engines, mb, mercedes, rod, sdl
Search this Thread:
Advanced Search
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Copyright © 2001-2012 InternetBrands, Inc. / MBWorld.org. All Rights Reserved.
Everyone's Personal Details
SEO by vBSEO 3.5.2
