Go Back   MBWorld.org Forums > Mercedes-Benz Sedans > S-Class (W126)
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Members Insurance Search Today's Posts Mark Forums Read CarsGarageVendors
Welcome to MBWorld.org Forums
S-Class (W126) 1979-1991: 300 SE, 300 SEL, 380 SE, 380 SEL, 420 SEL, 500 SEL, 560 SEL, 360 SEC, 500 SEC, 580 SEC, 300 SD TURBODIESEL, 300 SDL TURBO, 350 SD TURBO, 350 SDL TURBO
LinkBack Thread Tools Search this Thread Rate Thread Display Modes
Old 02-28-2011, 11:15 AM   #1
Drives: '84MB300SD
Curious glow plug relay behavior?
I have a well kept '84MB300SD with 90K miles. Starts and runs well as long as the temps are above freezing. I think I have some weak glow plugs and plan to replace them. My questions is about my glow plug relay: When I start the car the glow plug light comes on as it should and the car starts. What is curious is that the glow plug light comes on intermittently but often once the car is running. It has done this since I purchased the car Sept'10 and the only change is that the frequency of the on/off cycle has now increased to about 3Hz...the noise coming from the relay on the front fender is annoying. Now get this: turning the headlights on turns the glow plug light off & stops the noise reliably!
I read somewhere that the glow plug light can come on while the car is running, but the problem can be with the plugs & not the relay. Does this make any sense? Shouldn't off be off? My big question is should I replace the relay as well as the plugs? I have thought about just replacing the plugs to see if the above behavior changes, but do not want to damage my new plugs with a defective relay. Any advice will be appreciated.
To remove this ad, register today or login if you already are registered!
OldFred is offline   Reply With Quote
Old 03-07-2011, 04:09 PM   #2
oldsinner111's Avatar
Drives: s320 and 300sd
nate rector
The newer upgraded relays are better.Also I believe you ignition switch need replacement.Its plastic and can crumble with age.
__________________
1999 S320 plus 125 nitrous shot hp,modified grille area,and cold air intake,wrapped exhaust manifold,wrapped air duct,cold air,ceramic pads,no cats
Borla exhaust one muffler14.4 1/4 mile 1983 300 SD not stock Mobil One ATF diesel rated oil both cars
oldsinner111 is offline   Reply With Quote
Old 03-07-2011, 04:29 PM   #3
Drives: '84MB300SD
OldSinner111: Thanks for the advice. My car has a Hella GP relay that came in the car when I bought it last year. I ordered a Bosch GP relay to replace it as many have said I should, but the online vendor shipped me a HUCO (Made in Germany) GP relay. Should I return the HUCO and pursue a Bosch OR just put the HUCO in? Do you have any experience with the long-term reliability of the HUCO GP relays? Thanks
Old 03-17-2011, 11:57 AM   #4
Drives: It changes all the time
The system is designed to make the light flash when you have a glow plug failure. To determine which plug has failed, remove the large plug from the global relay. With one lead of a digital ohmmeter grounded to the engine, probe each of the five connectors at the plug. The little number next to each connector corresponds with that glow plug reading from radiator towards firewall. Any glow plug that shows an open is obviously defective and needs to be replaced. You should also replace any glow plug that has a resistance much above one ohm.
hineywineries is offline   Reply With Quote
Tags
126, 1979, 300sd, 300sdl, benz, flashing, glow, huco, light, make, mercedes, noise, on, plug, relay, weak
Search this Thread:
Advanced Search
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Copyright © 2001-2012 InternetBrands, Inc. / MBWorld.org. All Rights Reserved.
Everyone's Personal Details
SEO by vBSEO 3.5.2
