Go Back   MBWorld.org Forums > Mercedes-Benz Sedans > S-Class (W126)
Sign in using an external account
Register Forgot Password?
Home Register Photos FAQ Members Insurance Search Today's Posts Mark Forums Read CarsGarageVendors TSB & Recalls
S-Class (W126) 1979-1991: 300 SE, 300 SEL, 380 SE, 380 SEL, 420 SEL, 500 SEL, 560 SEL, 360 SEC, 500 SEC, 580 SEC, 300 SD TURBODIESEL, 300 SDL TURBO, 350 SD TURBO, 350 SDL TURBO
Welcome to MBWorld.org Forums
submit to reddit
LinkBack Thread Tools Search this Thread Rate Thread Display Modes
Old 05-26-2011, 10:53 PM   #1
Drives: 1991 300 SE
1991 300SE: Premium or regular gas?
Hi, I have a 1991 300SE and my dad has been filling it up with regular gas for a pretty long time now. The car used to be my grandma's and when she was alive and she always filled it up with premium and would always get into arguments with my dad saying how it has to be filled up with premium rather than regular. My dad, of course, never listened to her and would always reiterate that regular is better and cheaper for the car. Well, now my grandma has passed away over a year ago and now it is officially our car via her will and my dad still continues to fill it up with regular. Now, I recently acquired my license(18 y.o here) and have been learning a lot about cars and Mercedes. My dad is letting my use the Mercedes until I go to college next year and I keep telling him that it should be filled up with premium but he refuses to allow me to do so. He says that the only thing premium does is that it is a little bit cleaner and gives you a little bit more "oomph" on the highway when you are passing cars. I tried to explain to him that while that is the case, it also gives the car better MPG and is faster and more efficient at all times, not just on the highway. He doesn't think so. I am going to show him this page after you guys give some, hopefully good and informed answers on this issue. Thanks!
To remove this ad, register today or login if you already are registered!
crazekid362 is offline   Reply With Quote
Old 05-27-2011, 11:02 AM   #2
oldsinner111's Avatar
Drives: s320 and 300sd
I have a 99 S320 and I run half regular and half super.Been running fine these 2 years.No pinging at all.
__________________
1999 S320 plus nitrous 355 hp. 1983 300 SD not stock
oldsinner111 is offline   Reply With Quote
Old 06-20-2011, 05:19 PM   #3
Drives: '94 E420 177K- (for sale, parts car) '92 300E 179K (LEMON)
http://www.facebook.com/jmashhhhh
I ran regular for 2 years in my 94 E420... sure, I have tons of issues with the car because it was never garaged, but the engine is still running strong. While super might be more efficient it still costs A LOT more, and the ends will probably not justify the means.
JMcGlash is offline   Reply With Quote
Old 06-21-2011, 10:56 PM   #4
Drives: M
re
1983 300sd with cold air,straight exhaust,monark nozzles,electric fan,electric boost pump,and wvo capable 2 tank system,boost at 16 psi. 126 diesels at yahoo groups.2" lift in rears,and rear spoilers both cars.
__________________
seo forum
lubnakazi.kazi is offline   Reply With Quote
Old 06-23-2011, 12:01 AM   #5
Richard / E320's Avatar
Drives: 2001 E320
Sure, it will run on regular gasoline, but there is a reason Mercedes puts a sticker on the car that says 'premium fuel only'.
Any time I think of using anything but premium gasoline, I think of the old Fram commercials, with the mechanic saying 'you can pay me now or pay me later'.
Since it's your vehicle, it's your choice of what you think is best for you.
__________________
Richard / E320
2001 M-B E320 / Glacier White w/ Java Leather / 18" AMG Style III & Bridgestone Potenza's / H&R Springs
Richard / E320 is offline   Reply With Quote
Old 07-10-2011, 08:12 PM   #6
Drives: 300se
Premium fuel has no added energy and is no cleaner than regular fuel. The additional octane allows designers to increase compression and heat in the cylinder without triggering pre-ignition.
If your car does not rattle or ping under load with regular you can continue using it without harm.
See here:http://www.scientificamerican.com/ar...tion-premium-g
Best wishes
Dan
dstate1 is offline   Reply With Quote
Old 07-12-2011, 06:10 AM   #7
Drives: Maruti Swift
i am using premium and really happy with that..not a single issue i face with car from last year
nickone is offline   Reply With Quote
Old 08-24-2011, 12:37 AM   #8
Drives: 1989 300 SE
unblended if you can find it.
A car made in 1991 may, or may not be designed for the ethanol-blended gasoline, you will need to do some research to decide.
Personally, in my 1989 300SE I get the best performance with 91 octane clean gasoline, that is, unblended with ethanol. I don't believe my German-made 1989 straight6 was really intended to burn ethanol blends. on long stretches of highway when it is smoothly purring at 80 like it will go all day, it's whispering to me I made the right decision. Yes it is $4.37 a gal, but don't judge until you try unblended Premium (91) for yourself.
schurmann is offline   Reply With Quote
Old 10-15-2011, 07:58 PM   #9
Drives: 1991 300SE
Agreed. Only thing I'll add to the highway driving is the easy use of far and away the best cruise control ever placed in a vehicle.
seda is offline   Reply With Quote
Old 10-16-2011, 07:28 PM   #10
C280 Sport's Avatar
Location: Saratoga,Springs New York and Sarasota, Florida.
Drives: 87 420SEL, 97 E320, 02 E320, 05 C240, 06 CL600
http://www.facebook.com/http://www.facebook.com/#!/profile.php?id=742419241
Send a message via AIM to C280 Sport
Run the Premium. There is a reason why Mercedes and many other car makes tell you to. A high compression ratio and/or run at a high temperature and regular gas will ignite prematurely causing detonation and eventually the car WILL knock. Not to mention you get the best performance out of the engine as well. Just make sure your dad puts that he runs regular gas in the ad if and when he sells it... I am sure buyers will come a running.
__________________
06 CL600
05 C240 4Matic
02 E320 Special Edition
97 E320
87 420SEL
C280 Sport is offline   Reply With Quote
Old 10-20-2011, 09:13 AM   #11
Drives: 300 SEL 1988
My owners manual (260SE, 300SE & SEL) is very clear . "A minimum octane rating of 98 RON and 88 MON is necessary." However on the inside back page a sticker has been put over a line of writing to hide it. The sticker says "Fuel - unleaded only, minimum 91 RON/82 MON."
You wouldn't get knocking with regular fuel because the anti-knock mechanisms would come into play. See http://www.torquecars.com/articles/f...ne-ratings.php
3OO-SEL-AU is offline   Reply With Quote
Old 11-13-2011, 11:44 AM   #12
Drives: 1983 300D
Premium only. All MB's engines do.
NakedApe is offline   Reply With Quote
MBWorld
Mercedes SLR McLaren
Paid Advertisement
submit to reddit
Tags
1991, 26, 300, 300se, 87, 91, binz, fuel, gas, gasoline, mercedes, mercedesbenz, merceses, psi, regular, se, unleaded, w126
Search this Thread:
Advanced Search
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Advertise on MBWorld - Contact Us - MBWorld.org Forums - Archive - Top
Advertise on MBWorld.org - Terms of Service - Privacy Policy - Jobs
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2
Copyright © 2001-2011 InternetBrands, Inc. / MBWorld.org. All Rights Reserved.
Everyone's Personal Details
