Sign in using an external account
| S-Class (W126) 1979-1991: 300 SE, 300 SEL, 380 SE, 380 SEL, 420 SEL, 500 SEL, 560 SEL, 360 SEC, 500 SEC, 580 SEC, 300 SD TURBODIESEL, 300 SDL TURBO, 350 SD TURBO, 350 SDL TURBO |
LinkBack | Thread Tools | Search this Thread | Rate Thread | Display Modes |
#1 | ||
Drives: 1986 Mercedes 300SEL
Difficulty starting
#2 | |
Drives: 2001 E320
Quote:
I had all the vacuum lines replaced, along with all the rubber tubing that had anything to due with air intake or fuel, new spark plugs, new fuel injectors and seals. I also replaced items like a couple of cold start valves and idle value (don't remember the exact names of the actual parts) but three valves or solenoids. It had great fuel pressure but the next thing the indy shop wanted to try was the fuel injection head. If they could have assured me that would have solved the problem, I would have done it, but the shop couldn't make that promise and after spending $1,800 trying to chase down the problem, I gave up. I sure miss that SEL though, and have always wished I could have sorted out the problem. EDIT: Poked around some of my old threads here and the other M-B forum, and found the more correct names of the following parts I had replaced trying to get the issue resolved. Part #0065454524 Behr Thermot-Tronik Engine Temperature Sensor; 105/115 Degree C with Green Insulator and 3 Pin Connector Part #0280130044 Bosch Engine Temperature Sensor; 2 Pole Green Part # 0001411625 VDO-Siemens Idle Air/Speed Control Valve
__________________
Richard / E320 2001 M-B E320 / Glacier White w/ Java Leather / 18" AMG Style III & Bridgestone Potenza's / H&R Springs Last edited by Richard / E320; 06-15-2011 at 01:07 AM. |
| Tags |
| 1987, 2001, 420sel, 560sel, adjust, e320, fuel, idle, mercedes, mixture, rough, rpm, set, starting, trouble |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Display Modes | Rate This Thread |
