Sign in using an external account
| Home | Register | Photos | FAQ | Members | Insurance | Search | Today's Posts | Mark Forums Read | Cars | Garage | Vendors | TSB & Recalls |
| S-Class (W126) 1979-1991: 300 SE, 300 SEL, 380 SE, 380 SEL, 420 SEL, 500 SEL, 560 SEL, 360 SEC, 500 SEC, 580 SEC, 300 SD TURBODIESEL, 300 SDL TURBO, 350 SD TURBO, 350 SDL TURBO |
LinkBack | Thread Tools | Search this Thread | Rate Thread | Display Modes |
#1 | ||
Drives: 300SE
__________________
1966 Porsche 912 1981 Mercedes 380SL 1984 Porsche 944 1986 Jaguar XJS V12 1986 Corvette Z51 1989 Mercedes 300SE 2010 BMW 328i/M Sport |
#2 |
Drives: 1991 300SE
First off, 63K...thatsnice. Not much wisdom here but I have a '91 300SE that I love and I've had the same issue you're experiencing since I became the second owner of mine in '07. I say same issue but I've found that if I just hold the key in the ignition position the car will eventually start. Regardless of outside temperature. Then if I cut it off directly after starting the car the first time it will then start like turning on a light each successive attempt without fail. I have asked several "experts" about this issue and I've been told that's just the way it is. I may have started a thread here about this very thing. Additionally, when I checked the car's manual sure enough it said that you may need to hold the key in the ignition position "for up to 4 seconds" for the car to start.
Again, you have said you may need to depress the accelerator but you should double check that you actually need to do this in order for the car to start. All of this said if you find or have found a cold start fix please post it up. |
#3 |
Drives: 1982 280se
look at the fuel pressure accumulator, near the fuel filter. I had a problem with my 280se as the accumulator was broken. It keeps a head of fuel pressure available for start up. If this is broken it takes a few seconds to build up fuel pressure for it to start.
hope this helps |
| Tags |
| 1966, 1981, 300e, 380sl, bad, cold, csv, failing, mercedes, porsche, regulator, runs, start, switch, valve, w126 |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Display Modes | Rate This Thread |
