Go Back   MBWorld.org Forums > Mercedes-Benz Sedans > S-Class (W126)
Sign in using an external account
Register Forgot Password?
Home Register Photos FAQ Members Insurance Search Today's Posts Mark Forums Read CarsGarageVendors TSB & Recalls
S-Class (W126) 1979-1991: 300 SE, 300 SEL, 380 SE, 380 SEL, 420 SEL, 500 SEL, 560 SEL, 360 SEC, 500 SEC, 580 SEC, 300 SD TURBODIESEL, 300 SDL TURBO, 350 SD TURBO, 350 SDL TURBO
Welcome to MBWorld.org Forums
submit to reddit
LinkBack Thread Tools Search this Thread Rate Thread Display Modes
Old 10-07-2011, 03:44 PM   #1
Drives: 1988 W126 420SE
FIRST TIME W126 OWNER NEEDS ADVISE!!
JUST BOUGHT A 88 420SE WITH 155000 MILES ON THE CLOCK. THE PROBLEM IS THAT I THINK IT'S ONLY RUNNING ON 6 CYLINDERS ON IDLE BUT WHEN I REV IT UP IT SOUNDS FINE. IF I TAKE OFF THE HT LEADS FROM THE BACK TWO CYLINDERS ON THE LEFT HAND HEAD (WHEN LOOKING FROM THE FRONT OFF THE ENGINE) THERE IS NO CHANGE TO THE ENGINE NOTE???? IT'S HAD A NEW FUEL PUMP AND FILTER, NEW HT LEADS, NEW SPARK PLUGS IT ALSO HAD A NEW DIZZY CAP AND ROTOR ABOUT 5 YEARS AGO. THE CAR HAS SAT SINCE 2006 WITHOUT BEING USED SO THE GAS ISN'T GREAT.
MY DAD WHO'S A RETIRED MECHANIC INSISTS THAT ITS OK AND JUST NEEDS A GOOD RUN, CAN ANYONE OUT THERE SHED SOME LIGHT ON THIS FOR ME PLEASE.
THANKS
To remove this ad, register today or login if you already are registered!
MONTY420 is offline   Reply With Quote
Old 10-31-2011, 10:16 AM   #2
CLOCK123's Avatar
Drives: 1989560SEL
MONTY 420 FILL THE GAS TANK WITH PREMIUM GAS THEN ADD CAN OF INJECTOR CLEANER DRIVE THE CAR IT WILL CLEAN THING OUT NEXT GASS FILL UP DO THE SAME THING DRIVE DRIVE DRIVE
CLOCK123 is offline   Reply With Quote
MBWorld
Mercedes SLR McLaren
Paid Advertisement
submit to reddit
Tags
changing, cleaning, gas, ht, injector, leads, oil, plugs, remove, sat, spark, tank, thr, w126, years
Search this Thread:
Advanced Search
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Advertise on MBWorld - Contact Us - MBWorld.org Forums - Archive - Top
Advertise on MBWorld.org - Terms of Service - Privacy Policy - Jobs
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2
Copyright © 2001-2011 InternetBrands, Inc. / MBWorld.org. All Rights Reserved.
Everyone's Personal Details
