Sign in using an external account
| Home | Register | Photos | FAQ | Members | Insurance | Search | Today's Posts | Mark Forums Read | Cars | Garage | Vendors | TSB & Recalls |
| S-Class (W126) 1979-1991: 300 SE, 300 SEL, 380 SE, 380 SEL, 420 SEL, 500 SEL, 560 SEL, 360 SEC, 500 SEC, 580 SEC, 300 SD TURBODIESEL, 300 SDL TURBO, 350 SD TURBO, 350 SDL TURBO |
LinkBack | Thread Tools | Search this Thread | Rate Thread | Display Modes |
#1 | ||
DIY tune-up
#2 |
Btw my car is an 89 560sel 77k miles. I'd like to do brakes and rotors all around, any help there would be appreciated.
Thanks again |
#3 |
Drives: 1987 300 SDL
www.autohausaz.com may be your best friend!!!
Buy the sensors as well. Easy to deal with, as pins holding down pads are a breeze to take out. Get calipers out, but try to tie them to a temp location so as they don't hang from the hose. Rears could be a pain as rust and heat seals them in place, but wd-40 and a few taps or wacks with a mallet will do the trick. Make sure e-brake is not engaged. Bleed the system while at it, make sure reservoir at the master cylinder is all the way up (full) as chamber is divided in two and fluid from front half cascades into rear half, which supply fluid to the rear of the car. A big bottle of brake fluid about 20 oz should be enough flush the whole system. BTW, no need for mitty vacum tools, as someone pumping three or four times and holding down pedal, while you open and close bleeder valve is enough. Check that all calipers are clean and functional prior to re-assembly.
__________________
| Tags |
| 560, brake, chamber, code, discount, diy, diytune, fluid, sel, sensor, tricks, tune, tuneup, w126 |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Display Modes | Rate This Thread |
