Sign in using an external account
| Home | Register | Photos | FAQ | Members | Insurance | Search | Today's Posts | Mark Forums Read | Cars | Garage | Vendors | TSB & Recalls |
| S-Class (W126) 1979-1991: 300 SE, 300 SEL, 380 SE, 380 SEL, 420 SEL, 500 SEL, 560 SEL, 360 SEC, 500 SEC, 580 SEC, 300 SD TURBODIESEL, 300 SDL TURBO, 350 SD TURBO, 350 SDL TURBO |
LinkBack | Thread Tools | Search this Thread | Rate Thread | Display Modes |
#1 | ||
Drives: 1990 300 SE
#2 |
Drives: C32 AMG
My Dad has a w124 300se and he had that issue. His fix was the fuel pump relay...(simple replacement at $70 Australian dollars)
#3 |
Drives: 1990 300 SE
I have W126, but thanks a lot, relay should't be that expensive for W126, so I'll try that.
#4 |
That's what happened to my W124 260E. The fuel pump relay is the most overlook parts since there is no fault codes or error to detect it. My indie pulled it out to show me the internal part of the circuitry, you be amazed the amount of hairline splits if you view them outdoor during a sunny day. Hope you got yours sorted. Cheers!
#5 |
Drives: 1990 300 SE
You were right! 99eur (at MB local dealer) and new relay solved the problem. Thanks a lot guys! Now I'm going to find some info about ASR (control light is often on ;-) and, at the moment, everything will be ok ;-)
All best! |
#6 |
Drives: C32 AMG
Excellent, happy to hear that. And my mistake at first post: Dad has a w126 300se (ex consulate car from Japan/custom stuff added etc) not a w124. Cheers,
#7 |
Drives: 1990 300 SE
My best friend has also W126 300SE from Swiss embassy ;-)
PS.Those relays ;-) ASR problem was the same stuff - relay. Maybe I should collect some for the future (next 5-20 years). Anyone did that? Any suggestion which ones? 2 tips I already have ;-) |
| Tags |
| 300se, benz, code, died, drive, driving, drivingorg, drving, dying, engine, m103, mercedes, rotella, stalls, unexpectedly, w126 |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Display Modes | Rate This Thread |
