Go Back   MBWorld.org Forums > Mercedes-Benz Sedans > S-Class (W126)
Sign in using an external account
Register Forgot Password?
Home Register Photos FAQ Members Insurance Search Today's Posts Mark Forums Read CarsGarageVendors TSB & Recalls
S-Class (W126) 1979-1991: 300 SE, 300 SEL, 380 SE, 380 SEL, 420 SEL, 500 SEL, 560 SEL, 360 SEC, 500 SEC, 580 SEC, 300 SD TURBODIESEL, 300 SDL TURBO, 350 SD TURBO, 350 SDL TURBO
Welcome to MBWorld.org Forums
submit to reddit
LinkBack Thread Tools Search this Thread Rate Thread Display Modes
Old 01-13-2012, 10:40 AM   #1
Drives: 1981 300SD W126
300SD custom oil return?
My turbo oil return is leaking, I replaced it, it's still leaking.
I went to the local yard and got another turbo and I'm rebuilding it, it's on my bench now. I want a more permanent solution to the oil return, that provides a connection at the bottom without a flexible seal.
My current plan is to drain the pan, clean the hole thoroughly, and JB Weld (ugh, I know, but anyway) a fitting into the hole. But there has to be a better way, right? If the engine were out of the vehicle I could maybe thread a hole in there, but that's not happening right now.
Does anyone have a better idea? I realize the penalty for failure if I get this wrong. But I cannot live with this big ugly oil leak. I think there's a gouge in there at the sealing surface.
To remove this ad, register today or login if you already are registered!
drinkypoo is offline   Reply With Quote
MBWorld
Mercedes SLR McLaren
Paid Advertisement
submit to reddit
Tags
300sd, drain, flexible, forum, leak, leaks, oil, tube, turbo, w126
Search this Thread:
Advanced Search
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Advertise on MBWorld - Contact Us - MBWorld.org Forums - Archive - Top
Advertise on MBWorld.org - Terms of Service - Privacy Policy - Jobs
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2
Copyright © 2001-2011 InternetBrands, Inc. / MBWorld.org. All Rights Reserved.
Everyone's Personal Details
