Sign in using an external account
| Home | Register | Photos | FAQ | Members | Insurance | Search | Today's Posts | Mark Forums Read | Cars | Garage | Vendors | TSB & Recalls |
| S-Class (W126) 1979-1991: 300 SE, 300 SEL, 380 SE, 380 SEL, 420 SEL, 500 SEL, 560 SEL, 360 SEC, 500 SEC, 580 SEC, 300 SD TURBODIESEL, 300 SDL TURBO, 350 SD TURBO, 350 SDL TURBO |
LinkBack | Thread Tools | Search this Thread | Rate Thread | Display Modes |
#1 | ||
Drives: 1989 420 SEL
Broke down: help
#2 |
Drives: 1986 560SEL, 97 BMW 740iL
Did you check under the hood to see if you belt is broken?
__________________
1986 560SEL Silver/Dark Blue W126 Alpine CVA 1004 with 6.5" display, Alpine DVD navigation system, Parrot CK3100 Bluetooth carkit, European headlights. |
#3 |
I apologize for not following up.
I was on the side of the turnpike cold and missing some Saturday night activities which had been planned for awhile. The belt was not broken. But it was in bad condition. The alternator had gone. I bought a re-manufactured unit off peach parts. And installed it, aside from finding my wrenches getting to the store to buy some gum cutter, and finding an appropriate persuasion bar, no problem. I am having an issue with returning the core. Really, the only problem is finding the time to box it up and send it back. While I was at it I replaced all of the belts, as they looked pretty poor. The double belt to the power-steering was easy once I found the bolts. The one to the alternator the same. I am having trouble swinging the tension roller to keep the good pressure on the belt for the compressor. The alternator belt, cake. But remember to loosen the screw on the back. The air pump was a problem. I could not for the like of me, or the jb gum cutter in the world get the air pump to swing far enough to get the belt over it. Unable to accept failure. I took a risk, wrapped the belt as far as I could from the bottom up, and turned the engine over. Luckily, the belt popped right into place. If anyone has advice for raising the tensionning roller, it would be helpful. Anyone having trouble replacing belts, or their alternator, (Disclaimer: I am in no way a certified reliable source, and take no responsibility for any terrible advice I give.) I would be happy to advise what I found successful. I am still having an issue where my car shifts at 3500 rpms. I don't know why and haven't found an answer. Any suggestions? I saw a topic about this a few weeks ago, but I haven't been able to find it since then. |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Display Modes | Rate This Thread |
