Go Back   MBWorld.org Forums > Mercedes-Benz Sedans > S-Class (W126)
Sign in using an external account
Register Forgot Password?
Home Register Photos FAQ Members Insurance Search Today's Posts Mark Forums Read CarsGarageVendors TSB & Recalls
S-Class (W126) 1979-1991: 300 SE, 300 SEL, 380 SE, 380 SEL, 420 SEL, 500 SEL, 560 SEL, 360 SEC, 500 SEC, 580 SEC, 300 SD TURBODIESEL, 300 SDL TURBO, 350 SD TURBO, 350 SDL TURBO
Welcome to MBWorld.org Forums
submit to reddit
LinkBack Thread Tools Search this Thread Rate Thread Display Modes
Old 02-02-2012, 09:53 AM   #1
Drives: 300sd
300sd new Starter equals 0 power in car
I installed a new starter, and unfortunatlly put the main wires on in reverse. When i touched the batter positive cable to the battery, there was a large spark. I instantly pulled the cable off. I corrected the wire positions on the starter and when i connected the battery, now there is now power shown in the car. no dash lights, glow light, head lights. and of course the starter does not start. Batter is fully charged. I checked cont to the junction for the altenator, all checks good to starter and battery. Ive been agonizing over this for 2 weeks now. Please help. Thank you.
Bruce.
To remove this ad, register today or login if you already are registered!
Brucifer28 is offline   Reply With Quote
Old 02-02-2012, 12:51 PM   #2
RobertG's Avatar
Drives: things with and without wheels
Check your fuses, all of them
RobertG is offline   Reply With Quote
Old 02-02-2012, 01:02 PM   #3
Drives: 300sd
I have checked all the fuses in the black box, they all seem good.
Old 02-02-2012, 02:29 PM   #4
RobertG's Avatar
What year is your 300sd?
Old 02-02-2012, 06:23 PM   #5
Drives: 300sd
Is it possible that something inside the starter/solonoid was ruined by the 1 second cross wires??
My car is a 1982 300 SD Turbo Diesel Automatic 4 Door
Old 02-02-2012, 07:46 PM   #6
RobertG's Avatar
reversing polarity it is possible, i'll look it up in my stuff and try to get you some info.
Old 02-02-2012, 08:14 PM   #7
RobertG's Avatar
check for power at the starter post as well as power at the alternator if you have power there then go to the power distribution post under the fuse box(c-100) I hope you have power there or evidence of burned wires that might be an easy fix.
Old 02-04-2012, 10:31 AM   #8
Drives: 300sd
All wires seem good and have cont. I guess i will replace all the fuses, just incase its one of them. If anybody has had similar problem, please do contact me. I am not rich and cannot afford a merc mechanic to come to my house and fix it....Once again,
all i did was put a new starter in my fully working car. It just cesed working one morning, the starter, no turn over or cranking. all the lights and dash warning lights were working fine, when you turned the key, nothing would happen, ie no starter crank. I purchased a new starter from Napa. it is a Bosch, it came with new solonoid attached. i installed it, with the battery disconnected. when i put the positive on the battery, sparks flew, i immediatly removed the battery cable. switched the starter wires, and now no power inside car. there is power at the starter, there is power at the wheel well junction.
Old 02-05-2012, 01:23 PM   #9
RobertG's Avatar
If you checked the hot side to the fuses and is hot ,now check the ground side at the battery all the way to the engine, you might find melted connections or carboned up connection from spark that you made.
MBWorld
Mercedes SLR McLaren
Paid Advertisement
submit to reddit
Tags
1982, 300sd, battery, car, located, mercedes, power, replacement, starter, w126
Search this Thread:
Advanced Search
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Advertise on MBWorld - Contact Us - MBWorld.org Forums - Archive - Top
Advertise on MBWorld.org - Terms of Service - Privacy Policy - Jobs
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2
Copyright © 2001-2011 InternetBrands, Inc. / MBWorld.org. All Rights Reserved.
Everyone's Personal Details
