Go Back   MBWorld.org Forums > Mercedes-Benz Sedans > S-Class (W126)
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Members Insurance Search Today's Posts Mark Forums Read CarsGarageVendors
Welcome to MBWorld.org Forums
S-Class (W126) 1979-1991: 300 SE, 300 SEL, 380 SE, 380 SEL, 420 SEL, 500 SEL, 560 SEL, 360 SEC, 500 SEC, 580 SEC, 300 SD TURBODIESEL, 300 SDL TURBO, 350 SD TURBO, 350 SDL TURBO
LinkBack Thread Tools Search this Thread Rate Thread Display Modes
Old 02-08-2012, 09:10 PM   #1
jumph4x's Avatar
Drives: 1987 300 SDL
New Owner, Question About Headlights
Hey guys,
I'm a proud new owner of a nicely preserved 1987 300SDL. Has a little bit of rust, but is otherwise an amazing car.
However, left headlight has a crack and a hole in the glass and right headlight surround is damaged as well. I want to buy a set of headlights for this car, but I have a question:
Most of the cars I see have the boring single piece insert setup like this, mine included:
Click the image to open in full size.
However, every so often I see a nice looking two piece design, yet cannot trace which car it came on or where to purchase it:
Help me out!
To remove this ad, register today or login if you already are registered!
__________________
Got myself a real Mercedes: 1987 300 SDL.
jumph4x is offline   Reply With Quote
Old 02-08-2012, 09:12 PM   #2
jumph4x's Avatar
I may have just found the answer, looks like those came on 1984 300 SD cars in the US. Will these fit mine?
__________________
Old 02-10-2012, 02:13 PM   #3
jumph4x's Avatar
This forum is dead, huh?
__________________
Old 02-14-2012, 02:05 AM   #4
Drives: 1989 300 SE
I like those new ones with the exposed fogs in the pic there. i gotta admit that this is the first time Ive seen that particular one, most of the time they are solid silvery grey and not the clear plastic frame!
My 300SE takes the ones you originally have, and Ive already replaced the frames with new clear ones-
I'll research this too!
schurmann is offline   Reply With Quote
Old 02-14-2012, 04:57 PM   #5
Drives: '93-300 CE, '09 ML320 BluTec
Headlights
I've own two w126s, 83 and 86 I have changed out the lights on both with Euros. After a minor front end collision I needed to replace the euros on my 86 again. I was able to find less expensive set made by an after market co, I believe Depro. They have a glass face that don't fade and can be changed and the light output turned out to work very well. Look at ebay. Enjoy your car.
'93 300ce is offline   Reply With Quote
Old 02-20-2012, 01:54 PM   #6
cool_lagoon's Avatar
Drives: (1960) 300d, S550 AMG S500 S600 560SEL
when you say hole in the glass did you mean the main beam or the plastic part? the main beam can easily be purchased at any MB shop, they are locally available and not expensive and you need not change the whole assembly. Have you seen the euro version headlamp assy? much cleaner and better looking, it comes with one solid piece of thick glass covering the fog and the main beam.
__________________
cool_lagoon is offline   Reply With Quote
Tags
1987, 300, 3oo, 500, 560, assembly, change, fit, headlamp, headlight, headlights, lens, mercedes, remove, sdl, sel
Search this Thread:
Advanced Search
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Copyright © 2001-2012 InternetBrands, Inc. / MBWorld.org. All Rights Reserved.
Everyone's Personal Details
SEO by vBSEO 3.5.2
