Go Back   MBWorld.org Forums > Mercedes-Benz Sedans > S-Class (W126)
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Members Insurance Search Today's Posts Mark Forums Read CarsGarageVendors
Welcome to MBWorld.org Forums
S-Class (W126) 1979-1991: 300 SE, 300 SEL, 380 SE, 380 SEL, 420 SEL, 500 SEL, 560 SEL, 360 SEC, 500 SEC, 580 SEC, 300 SD TURBODIESEL, 300 SDL TURBO, 350 SD TURBO, 350 SDL TURBO
LinkBack Thread Tools Search this Thread Rate Thread Display Modes
Old 04-19-2012, 12:22 PM   #1
Drives: mb 1991 300se
DRIVER SIDE WINDOW GLASS OUT OF TRACK DOES NOT CLOSE
I have a 91-300SE, the driver window glass does not go up, the glass came out of the track which prevents the window from going up and down, the switch still works and the motor appears to be working fine, I took off the panel to inspect the problem and noticed that the glass was not in the track correctly, I am only able to push the window up manually, then I can open the window with the switch but the glass falls out of the track again into a crooked sideways position.
Any suggestions would be appreciated
To remove this ad, register today or login if you already are registered!
MB 1991 300SE is offline   Reply With Quote
Old 04-20-2012, 10:43 AM   #2
Drives: 1991 560SEC Teal 1989 420SEL Ice Blue 1984 500SEC White
Sounds like either the regulator or the slides.
The regulator is the part with the meshing teethed gears, used to lower and raise the window.
The slides are located on the bottom of the glass and fit into a slide, which allows the side to side allowance of the window.
Both would result in the scenario, as you have descibed it.
BENZITCH is offline   Reply With Quote
Old 04-20-2012, 12:19 PM   #3
HI BENZITCH
Thanks very much for your suggestions, I really do appreciate your advise, I will inspect the area and try to identify if the regulator or the slides is defective
Old 11-22-2012, 11:49 AM   #4
I hope this photo will help anyone who has any issues with their window regulator. The reason my window was not working, I discovered that one of the arms was broken, as you know this part cost about $300 from the dealer, so I had it welded and now it works fine
Tags
1989, 300, 300se, close, coming, driver, drivers, glass, glassis, mercedes, open, regulator, replace, sel, side, slide, track, window, windows
Search this Thread:
Advanced Search
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Copyright © 2001-2012 InternetBrands, Inc. / MBWorld.org. All Rights Reserved.
Everyone's Personal Details
SEO by vBSEO 3.5.2
