Sign in using an external account
| S-Class (W126) 1979-1991: 300 SE, 300 SEL, 380 SE, 380 SEL, 420 SEL, 500 SEL, 560 SEL, 360 SEC, 500 SEC, 580 SEC, 300 SD TURBODIESEL, 300 SDL TURBO, 350 SD TURBO, 350 SDL TURBO |
LinkBack | Thread Tools | Search this Thread | Rate Thread | Display Modes |
#1 | ||
Drives: 300sd
How to check tranny fluid level
#2 |
Drives: i drive them all, fast and hard
the dipstick is near the battery, also ask on benzworld, better w126 section
__________________
![]() 1985 500SEL Euro Nautic Blue - A Classic Beauty 1998 S500 Brilliant Silver 2001 S500 Almadine Black/AMG Sport Package - Smooth and Silky 2010 S550 Palladium Silver/AMG P2 - Refined and Luxurious 2005 C320wz Granite Grey/Fully Loaded - Sold and Missed already 2012 E63 AMG Iridium Silver - Performance Package |
#3 |
Drives: 95 e320 cabrio, 89 420 sel, 91 300e
Maybe this is more helpfull:
Yes measure the level with the engine running and warm. Carefull not to use a rag that has loose fibers as it will contaminate the oil. Clean, clean, clean is important. Paper towel is good. Make sure the oil is nice and pink, if brown and smelling burned, you have a problem |
#4 |
Drives: 1981 300SD, 1991 Geo Metro
Old post, I know, and I'm sure the OP has figured this out, but for anyone else who cares...Dexron/Mercon type transmission fluid. And remember to flip the little catch on the head of the dipstick (that threw me for a day or two...)
#5 |
Drives: hundayi i10
to check trans. fluid check Pull out the dipstick........Check the fluid........Wipe the dipstick with a clean, lint-free rag; then reinsert it and pull it out again..
......... classified website |
#6 |
Drives: 1984 5oo SEC
trans oil check
Not a dumb question. I'm assuming you have a 722.3 {W 4 A 040}4-speed trans.MB technical companion says the only true way to get an accurate reading is to make sure the car is on level ground.With a cold transmission,i.e. 68 degrees F to 86 degrees F.
1.Make sure parking brake is on with selector in position P. 2.Start car and let idle for one to two minutes. 3.Pullout the dipstick and wipe it clean with a lint free cloth or a piece of leather. 4.Insert the dipstick fully,then withdraw it and read the level.The engine must be idling throughout this procedure. 5.The fluid level in all w126 cars should be 5mm,or 3/16ths in below the minimum {lower} marking. I would use pennzoil dexron ii D series,but remember, dexron iii supercedes dexron ii d series. So use dexron iii. It will be alot easier to find. You can check it hot ,on level ground in park after about 11 to 15 miles of normal driving with trans temp at 176 degrees F, dipstick reading will be at the top notch.Do not overfill.If you have to add fluid, make sure to run the gear selector through R-N-D-N-R leaving it in each selection for a few seconds, then back to park and check the fluid level. I hope this helps. |
| Tags |
| 1982, 1985, 300, 300sd, 500, benzworld, check, fluid, level, mercedes, overfill, sd, sel, transmission, w126 |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Display Modes | Rate This Thread |
