Help 560 sputtering
280SL, 560SEL, C320
Help 560 sputtering
Motor is in good shape mechanically with new timing chain 1k miles on chainm. Car starts, idles nice, acts normal for a minute then starts sputtering with throttle. Sputtering gets worse quick and soon stalls. Let it sit for a few minutes: it starts and idles fine, will start out in gear well for a few seconds, do one shift, then the sputtering, lose all power, and stall. Compression is good Spark is good. How do I trouble shoot to the failure?
560 SEC AMG Clone
Could be the EZL or coil. Try getting a spare EZL from a PYP yard and see if it goes away. A new coil is relatively cheep. Also check your EHA to see if it is weeping (fuel dripping from bleed holes). If so it's shot.
Mike
Mike
280SL, 560SEL, C320
Great news: did my homework, knew my spark and compression were in good order from a bad coil issue 6 months ago. Read the codes and none, but while going back and forth between the car and my tool box, I heard the fuel pump groweling lower and louder than normal. Looking under the car I saw the power lead just sitting on the screw with no nut and little sparks flashing from the vibration of the idle. Problem solved.
