S-Class (W126) 1979-1991: 300 SE, 300 SEL, 380 SE, 380 SEL, 420 SEL, 500 SEL, 560 SEL, 360 SEC, 500 SEC, 580 SEC, 300 SD TURBODIESEL, 300 SDL TURBO, 350 SD TURBO, 350 SDL TURBO
1982 SD300 Driveshaft Support help
Old 02-22-2016, 06:56 PM
blsseattle's Avatar
1982 300SD Turbo Diesel
1982 300 SD Driveshaft Support help
Hi all. Thanks for any help. My 1982 300 SD Turbo Diesel needs a new drive shaft support. Its shot. Basically gone. I'm sure I have to remove the entire drive shaft. The shop near me says they can get the part(s) for $120. That seems crazy. Anyone know if this is a job I can do at home? Looks like it. Also, I think I can get the needed parts MUCH cheaper. Anyone know exactly which I need? Thanks again. -Mike
Old 02-23-2016, 08:11 AM
Plutoe's Avatar
Received 1,019 Likes on 947 Posts
1999 E300TD
Post your VIN!!
Old 02-28-2016, 01:02 AM
blsseattle's Avatar
Plutoe... Where? Why? I'm new to this forum.
Old 04-07-2016, 10:44 PM
OM617.95's Avatar
1982 300D
Originally Posted by Plutoe
Post your VIN!!
Please STFU with that. You don't need to know the VIN for every friggin' question asked here!
He posted exactly EVERYTHING you need to know to help him.
"1982" "300SD" Thats it. Thats all you need!
blsseattle, yes, the center support is easy. Mark the driveshaft alignment before you disassemble it.
You might need to heat the old bearing to get it off. Use some fine emery cloth to clean the shaft and the new bearing should slide on without excessive effort.
$120 is extreme, even if its a genuine Mercedes part.
http://www.autohausaz.com/pn/1264100181A
http://www.autohausaz.com/pn/0039812325
Replace the slip joint boot while you are there.
http://www.autohausaz.com/pn/2024110497
Replace the flex discs if they show any cracks in the rubber or they are more than 10 years old.
http://www.autohausaz.com/pn/1264100215
Quick Reply: 1982 SD300 Driveshaft Support help
