S-Class (W126) 1979-1991: 300 SE, 300 SEL, 380 SE, 380 SEL, 420 SEL, 500 SEL, 560 SEL, 360 SEC, 500 SEC, 580 SEC, 300 SD TURBODIESEL, 300 SDL TURBO, 350 SD TURBO, 350 SDL TURBO
Seat Removal Help
Old 03-16-2016, 04:34 PM
blsseattle's Avatar
1982 300SD Turbo Diesel
Seat Removal Help
My 82 300sd's driver seat is stuck all the way to the far back and I need to remove the seat. The seat motor sounds like its working but the seat won't move. I want to clean the track and do some troubleshooting. Any ideas on how to remove the seat while its still so far back and the bolts seemingly unreachable? Thanks
Old 03-16-2016, 06:50 PM
Plutoe's Avatar
Received 1,019 Likes on 947 Posts
1999 E300TD
I have no idea whether this will work, however remove the two from rail bolts and try and spread the rails to the point that you can lift up and pull out from the front!!
Quick Reply: Seat Removal Help
