97 S320 Air Pump Switchover Valve Lines
Ran a check engine light diagnostics. Indicated that it was Air Pump Switch over Valve. Opened the hood and found this line laying loose under the top radiator hose. I can see another one like this that is attached and runs from a three hole triangle on the manifold to the front of the engine just behind and above the top serpentine pulley. Cant see where this one belongs.
any help much appreciated
