Go Back   MBWorld.org Forums > Mercedes-Benz Sedans > S-Class (W140)
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Members Insurance Search Today's Posts Mark Forums Read CarsGarageVendors
Welcome to MBWorld.org Forums
S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
LinkBack Thread Tools Search this Thread Rate Thread Display Modes
Old 02-25-2009, 09:22 PM   #1
Drives: 94 mercedes s320
changed fluid on 94 s320
i just changed the transmission fluid on my s320 including filter
and also emptied converter. I added fluid and changed each gear as instructed
now when i go on highway the last gear wont change. i checked fluid it shows over the max point. i drained some to make it to the maximum point. when i drove car would barely take any gear. when i added drained oil it start taking gears fine except the last one. i think theres about 7L of castrol ATF dexron lll
what could be the problem. please help
To remove this ad, register today or login if you already are registered!
my_galaxy is offline   Reply With Quote
Old 03-11-2009, 11:39 PM   #2
Drives: e320,e55.s600
You should have a 722.605 transmission, it has an electric valve body, you have to run Fibe # 22806 dexron III-H or MBZ A001 989 21 03 10. The fluid has to be non conductive. Also you may have not installed the filter correctly. that would make it need a higher fluid level to suck up the fluid. The bad news, Febi is about $13 a liter and the MBZ stuff is about $16 a liter. People try using the dexron III, it works a while. somtimes it wrecks the transmission and the valve body. I have seen the electronics also fried from the shorts to ground on the valves.
beermaker is offline   Reply With Quote
Old 03-16-2009, 05:44 AM   #3
syljua's Avatar
Drives: 1998 W140 S320
No, a 94 S320 cannot have had the 722.6 as original.
__________________
C140 CL500 1998
W123 230E 1984
syljua is offline   Reply With Quote
Old 03-16-2009, 12:03 PM   #4
BENZBOSS's Avatar
Drives: 1999 S420 1994 S320 1994 E320
Its 722.508
You need to clean valve body
BENZBOSS is offline   Reply With Quote
Old 03-18-2009, 02:52 PM   #5
OK. If you check the Elrctronic part catalog it shows that a 1994 s320 built for North Am. can have either a 722,508 or a 722.605. If your filter is a little square edge filter you have the 722.508 if the filter is a oval filter with a tube and o-ring that clips into place by pressing it. It's a 722.605 transmission. If you post your vin I can look up all of your build info. If you have the 605 trany often all that is wrong is the o-rings that seal the sylonoids into the valve body. let's figure out which trany you have first.
Old 03-21-2009, 11:31 PM   #6
BENZBOSS's Avatar
Transmission oil dip stick??Do you have one?
Old 04-01-2009, 07:03 AM   #7
syljua's Avatar
Quote:
No, it cannot! The 722.6 was not even introduced then, so you must be
misreading what EPC is telling you.
br,
syljua
__________________
C140 CL500 1998
W123 230E 1984
Old 04-07-2012, 06:35 PM   #8
Drives: porsche 944
Well, well,well, in August 2008, i decided to have the dealer change the tranny fluid and filter on my 1994 mercedes s320 ...my car only had 109200 km and driven properly for 15 years without any problems whatsoever. Since, then I put another 16,oookm and guess what, my reverse does not work any more when the tranny fluid warms up. This is nonsense! Did the mechanic at the dealer screw around with my tranny? What do I do now?
porschebuff is offline   Reply With Quote
Old 04-08-2012, 03:08 PM   #9
oldsinner111's Avatar
Drives: s320 and 300sd
nate rector
I use mobil one sync atf.no problems
__________________
1999 S320 plus 125 nitrous shot hp,modified grille area,and cold air intake,wrapped exhaust manifold,wrapped air duct,cold air,ceramic pads,no cats
Borla exhaust one muffler14.4 1/4 mile 1983 300 SD not stock Mobil One ATF diesel rated oil both cars
The Runaway Files by Tennessee Nate
oldsinner111 is offline   Reply With Quote
Old 04-09-2012, 10:31 PM   #10
Drives: porsche 944
Quote:
Ok, but will this atf fluid fix the reverse issue on my Merc S 320 1994 swb ? The car drives beautifully except for reverse. It will not move once the tranny has warmed up! Never experiened such an anomolie with autos in my 30 years of driving experience. The mechanic must have screwed with my tranny...i am convinced.
Old 04-10-2012, 04:22 AM   #11
nate rector
I'd hate for you to spend money to re fill your trans will atf.It sounds like when your fluid when its cold and thick your tranny works.I would try drain a quart out,and use the best trans additive for skipping trans.Other wise it sounds like its time for a rebuild.
If it works you might have wrong fluid.Some ATF are made to slip,and ATF Max for older trans do slip
__________________
Old 12-10-2012, 12:43 PM   #12
Drives: MERCEDES BENZ SE 300
USE MERCEDES BENZ OILS
My bests
CIGAR_LOUNGE is offline   Reply With Quote
Old 12-10-2012, 01:16 PM   #13
nate rector
always use MB fluid unless you race like me,I use MB approved Mobil One
__________________
Old 12-12-2012, 04:40 AM   #14
Drives: 94 S420,95 S500 ,96 S500
Quote:
All these trannys reverse fail so I dont think the mechanic did anything to your tranny..just time to rebuild it..
eddie a is offline   Reply With Quote
Old 12-12-2012, 06:00 AM   #15
nate rector
thats sad he has kilometers for mileage.
__________________
Old 01-03-2013, 09:03 PM   #16
There isnt any transmission fluid that will help your reverse problem, your reverse band is worn and needs replacing and if you were to replace it you should rebuild the complete transmission
Old 01-04-2013, 04:13 AM   #17
nate rector
yes no fluid that will fix reverse,but It was fine till he changed,could it be a part fell out,or overfilled and wet the wiring.Conductor plate?
I'm throwing out possible causes,how ever mercedes trans always lose reverse first, the ones that asked me.If I can't fix it right,I can rig it.
__________________
Old 01-04-2013, 06:00 AM   #18
yes no fluid that will fix reverse,but It was fine till he changed,could it be a part fell out,or overfilled and wet the sensors with ATF.Conductor plate?
I'm throwing out possible causes,how ever mercedes trans always lose reverse first.
What sensors would you be talking about?
Tags
1994, 722508, 7226, 722605, 94, atf, castrol, change, dexron, fluid, iii, mercedes, s320, transmission, trasmission, w140
Search this Thread:
Advanced Search
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Copyright © 2001-2012 InternetBrands, Inc. / MBWorld.org. All Rights Reserved.
Everyone's Personal Details
SEO by vBSEO 3.5.2
