S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
Antenna doesn't go down any more?
Old 11-23-2010, 06:28 PM
qha000's Avatar
Hi all,
Have you guys had this problem where the antenna stays up after turning the car off? This just started happening on my 97 S600, any ideas?
Thanks,
Old 11-24-2010, 07:44 AM
oldsinner111's Avatar
s320
In the trunk you will see where annt plugs in for power.This area can corode.Use a cleaner for contacts.
Old 10-15-2014, 10:42 PM
kingsyre's Avatar
1999 s420
antenna will not go down
Ive had the same problem recently the antenna will not go down any suggestions with fuses or anything
Old 10-23-2014, 08:00 PM
sprfrkr's Avatar
E350, W140 S, C63, G55, 420SEL, Prius, Dune Buggy, Ducati
1. Use silicone lubricant
2. Ensure your battery is healthy with a full charge. A low battery will show in an antenna not retracting all the way with about 3" exposed.
Old 10-23-2014, 11:06 PM
kingsyre's Avatar
1999 s420
antenna
Thank you
Quick Reply: Antenna doesn't go down any more?
