HELP! 96 S500 W140 RADIO DEAD
96 S500 W140,2 HARLEYS.IRONHORSE CHOPPER,01 FORD F150 HARLEY CREWCAB,98 CROWN VIC P71 POLICE SPECIAL
HI ALL i put this problem in audio section and figured i would try in here too. i replaced the battery on my s500 and now have a dead radio...will not turn on and have no display,even the anti theft light does not flash. i have checked fuse no.24 under the hood and it is good...i also disconnected the battery for five minutes and reconnected and still nothing....am i missing something??? any suggestions would be much appreciated...thanks in advance
LOFTY
p.s. everything worked fine before i replaced the battery.
LOFTY
1994 e320 coupe sportline
radio problem
I think I remember there is a inline fuse behind the radio.
It is easy to pull radio IF you have those little radio removal tools
also you will need the radio security code
THKS
thanks a lot hal...i just ordered the removal keys from ebay...as soon as they get here i will let you know if that was the problem or not.(fingers crossed)....once again much appreciated.
LOFTY
p.s. i do have the radio code
LOFTY
400 SEL
And the assumption here is...the radio was working before you change out your battery? Was the old battery working before you changed it out? (i.e. reason for changing out battery?)
yes the radio was working fine before i changed the battery....battery was getting low and what with winter on its way decided to purchase a new one.
400 SEL
Even the dash cluster removal tool can be purchase for around $10 at the dealership...so, don't go wasting your time on eBay for stuff like these.
Yeah, it's probably a good bet some where a fuse has blown.
cheers
lofty
FYI, next time...check first with your local MB dealership parts department...these tools are not expensive and we do not need to buy time off eBAY....I got mine at the dealer for less than $3.00...no waiting.
thks
lofty
LOFTY
LOFTY
Mine had a bad capacitor on the back. I plugged it in to 12 V, lightly touched all the components on the back and I noticed it fired up. Found the capacitor for under three dollars, soldered it on and the radios been good ever since.
radio not working anti theft not flashin 1998 W140 (S420)
i got all most the same problem non mine w140 radio not working anti theft not flashing already repalce head unit and the amp, the fuses are all good what to do next or where did you find the capacitor
It's been a few years but as I remember, I removed the radio, powered it up with 12 V and begin touching each component on the back of the unit. Once I put my finger on the capacitor get started working intermittently. Once I replaced it, it was all good.
Just because I had a bad capacitor does not mean that is your problem. With my limited experience in electronics all I can tell you is look closely (under magnification of possible) at every component for discoloration or swelling. Also look at the traces for a short. I got lucky as I put my finger on each component to see if anything changes. Good luck.
