Go Back   MBWorld.org Forums > Mercedes-Benz Sedans > S-Class (W140)
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Members Insurance Search Today's Posts Mark Forums Read CarsGarageVendors
Welcome to MBWorld.org Forums
S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
LinkBack Thread Tools Search this Thread Rate Thread Display Modes
Old 09-22-2011, 04:07 PM   #1
Drives: 1995 S 420
Angry slow pick up and cats get super hot
Hello all
here is what i have my car was running fine then all of a sudden she lost pick up it runs like it has a stopped up nose, it is hard to explain, but it does not run smooth like it should, one said that my cats were cloged up so i changed them still same problem come to find out my cats were fine, but when the shop was cutting the old ones off there was raw fuel in the pipes so that is saying that she is running rich, i dont know where to look iam getting to my wits end with this car,
i have changed the wire harness the dist caps and rotors the coils
this problem started a couple of days after i changed the dist and rotors
any body have had this problem
or any help
To remove this ad, register today or login if you already are registered!
pgcan is offline   Reply With Quote
Old 09-22-2011, 08:51 PM   #2
Drives: 400 SEL
check Mass Air Flow sensor
lcmlee is offline   Reply With Quote
Old 09-24-2011, 07:57 AM   #3
oldsinner111's Avatar
Drives: s320 and 300sd
nate rector
Did you use new ignition wires? That maybe your problem with old wires.
__________________
1999 S320 plus 125 nitrous shot hp,modified grille area,and cold air intake,wrapped exhaust manifold,wrapped air duct,cold air,ceramic pads,no cats
Borla exhaust one muffler14.4 1/4 mile 1983 300 SD not stock Mobil One ATF diesel rated oil both cars
oldsinner111 is offline   Reply With Quote
Old 09-24-2011, 08:44 AM   #4
Drives: 1995 S 420
No i did not put new wires on but one thing i notcied was that it is running rich
and there is a bad fuel smell and that it is burning a lot of fuel i cant drive the car there was raw fuel in the pipes Iam wondering if it could be my fuel pressure regalator, the car runs like it is stoped up
iam thinking there is a fuel problem
Old 09-24-2011, 01:50 PM   #5
nate rector
Well Sir it could be fouled plugs,you can at least pull plugs to see which are not firing.Then you know if its wires or coil boots.You can buy mass airflow cleaner.A dirty air flow sensor can give you all kind of problems.
__________________
Old 10-24-2011, 01:26 AM   #6
Drives: 2000 S 500 MERCEDES BNZ
I AM HAVING THE SAME PROBLEM WITH MY 95 S420,I REPLACED THE WIRING HARNESS WHICH WAS BAD,CRACKED INSULATION,AND ALSO REPLACED AIR MASS FLOW SENSOR.BUT NOTHING CHANGED,NO PICK UP ON ACCELERATION,RUNS RICH!!!
I DONT KNOW WHAT ELSE TO DO!!!
MOREN19241 is offline   Reply With Quote
Old 10-24-2011, 09:10 AM   #7
Drives: 1995 S 420
problem fixed
after all i done i it was one of my coils had burnt
Old 10-24-2011, 10:54 AM   #8
Thanks,I will have to check that and see if it takes care of my problem....
Tags
400, 400sel, 93, air, cat, fuel, hot, mercedes, meter, raw, removal, rich, running, s420, sel, sudden
Search this Thread:
Advanced Search
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Copyright © 2001-2012 InternetBrands, Inc. / MBWorld.org. All Rights Reserved.
Everyone's Personal Details
SEO by vBSEO 3.5.2
