Sign in using an external account
| Home | Register | Photos | FAQ | Members | Insurance | Search | Today's Posts | Mark Forums Read | Cars | Garage | Vendors | TSB & Recalls |
| S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC |
LinkBack | Thread Tools | Search this Thread | Rate Thread | Display Modes |
#1 | ||
Drives: 96 S500
96 S500
#2 | |
Drives: 1996 S500 Sedan
Quote:
#3 |
Drives: 96 S500
96 S500
Thank you for that information. Before I get the MB brand I will try properly "bleeding" it first. I've been told that I should have had some "weight" (ie people) in the back seat or trunk to help get all of the fluid & "air" out of the struts BEFORE putting in the new fluid. I'm not sure IF this is the solution but definitely worth a try. A mechanic explained it to me this way: "Just as you have to pump the brake pedal to properly bleed your brakes(ie applying pressure), the same principle should be applied to the struts". I plan on doing this in the next few days & will let you know IF it makes any difference. Thanks again for your feedback.
#4 | |
Quote:
I also found that for my car, the smoothest, best ride is when my rear shocks (Saches replacements) are about 1.5" higher than normal. So although my car now looks "lifted" a bit, it sure rides better! I experimented for a full afternoon setting it at different heights until I found the "sweet spot." Lesson: every car is slightly different, and a little fine tuning - especially on the suspension - makes all the difference! Good luck!
#5 | |
Drives: 96 S500
96 S500
I read about that "bleeding" process on one of the MB forum post. I will have to use "ramps" as mine sits too low to get beneath without it being on ramps. I can slide under car but don't have "near" enough room to access the lever control valve without raising the car up.
Quote:
| Tags |
| 96, accumulators, bleeding, changed, control, harsh, hydraulic, lever, mercedes, rear, ride, s500, struts, valve, work |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Display Modes | Rate This Thread |
