Sign in using an external account
| Home | Register | Photos | FAQ | Members | Insurance | Search | Today's Posts | Mark Forums Read | Cars | Garage | Vendors | TSB & Recalls |
| S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC |
LinkBack | Thread Tools | Search this Thread | Rate Thread | Display Modes |
#1 | ||
Drives: C230, CLK430, ML430
Just purchased my S but some sounds coming from front end
__________________
ML430 Nitrous 22'' Alba Force Wheels H&R Springs (down 1.25'') Bilstein Sport Struts 2x 12'' Kicker L7 Solobarics Custom Intake MagnaFlow Exhaust 10k HID's CLK430 K&N Filters C230 Komp 10k HID's K&N Filter Last edited by hersheylala007; 12-07-2011 at 09:55 AM. Reason: Added backround |
#2 |
Drives: s320 and 300sd
you probably need new sway bar links and sway bar bushings.A easy job.
__________________
1999 S320 plus nitrous 355 hp. |
#3 |
Drives: (1960) 300d, S550 AMG S500 S600 560SEL
the only way to know what's wrong is to send it to a dependable suspension garage for a visual and physical check up, there are lots of moving suspension parts as well as steering parts in the front that may cause the noise.
#4 |
Drives: 1997 S420
Check the sway bar/torsion bar links and ball joint adjustments, my car had the same thing and when I replaced the sway bars the bumping noise went away.
#5 |
__________________
#6 |
Drives: 1997 S420
cool_lagoon
What I meant to say was I replaced the parts mentioned and was told by a shop that I go to was that he adjusted the ball joints, he is a long time acquaintance and i trusted his saying, I guess he was pulling my leg. I am more of a motorcycle guy and not up yet on cars. I tried the high octane boost and marvel mystery oil route to try and blow out the carbon at 110 mph and the engine light is still on, i 'll keep trying. Hope you have luck fixing the front bumping noises, Sincerely, Stove
#7 |
Drives: 97' S320 & 00" S500
I have the same problem
OK, I know this is a late reply, but I have had the same problem on my 97 S320 for 4 years now. I have replaced the rotors and brakes and recently had the upper control arms replaced. Still the clunking noise. I was under the car today with my wife pressing it up and down to try to get the noise. I faintly heard something from the lower ball joint and even felt a grinding there as the car moved. I will try replacing those next.
#8 |
kcscout before you go on changing parts may i suggest you check first the following parts, stabilizer bushing, lower control arm bushing as well as the rubber boot of the ball joint, steering gear box, plus all the rubber and metal bushings you may see underneath for wear and tare and start spraying them first with silicone oil, make sure all oil have properly penetrated and circulated all through the rubber, one way to make sure it has already spread properly is after spraying take the car for a ride and runn to humps or un even road. If the noise persist then check for any loose bolt, another source of clunk noise is the rubber seat which is installed on the top and bottom of the coil springs.
__________________
#9 |
Thanks for the advice. I did have my silicon spray with me while I was under the car the other day and was using it to help eliminate joints. I was expecting the problem to be the lower control arm bushings, but they looked OK. All of the rubber seals around the various joints were in tact. The only parts that appeared to be worn were the lower ball joints. I did not consider the spring end plates though. I will check on those soon but since the spring is under constant tension, I don't see how there can be any play at the ends.
| Tags |
| 560sel, bad, bar, called, clunk, end, front, mercedes, noise, parts, pinion, rack, s600, steering, sway, vibration, w140 |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Display Modes | Rate This Thread |
