Go Back   MBWorld.org Forums > Mercedes-Benz Sedans > S-Class (W140)
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Members Insurance Search Today's Posts Mark Forums Read CarsGarageVendors
Welcome to MBWorld.org Forums
S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
LinkBack Thread Tools Search this Thread Rate Thread Display Modes
Old 04-06-2012, 05:28 PM   #1
Drives: 96 S500
96 S500 Idler Pulley/Smog Pump
I've been having a "high pitch" sound coming from my vehicle. For such a long time I thought it was my tranny because the sound is "synchronized" with every gear shifting. It also synchronizes with the engine like it's all "one" entity. So when I accelerate the "whinny" (not squeaky) sound gets higher. It's totally in synch with the engines every move speeding up & slowing down. So I took it to "Mr. Transmission" and they drove tested it and said the tranny is fine, has 190K on it. Had to believe them because what transmission place turns down $$$$. So after being perplexed I took it to another transmission shop and told him my complaint. I started car and he noticed the sound immediately. He put the "stethescope" on both side of engine while I pushed on gas pedal and said the high pitch sound is coming from my idler pulley area. Said it was so high with the scope on, he had to remove it from his ears In my opinion it sounds like a "bearing" is worn and not the pulley. I replaced serpentine belt about 500 miles ago and all the pulleys were tight. note: the sound was present even when I changed the belt but just didn't know what it was because I was just stuck on it being the tranny.
QUESTION: Should I just replace the pulley OR should I replace the entire Air/Smog pump with clutch & pulley? Would hate to replace pulley only to find out the "entire" assembly needs to be done. Any feedback from my Mercedes Benz family is appreciated!!
To remove this ad, register today or login if you already are registered!
starky is offline   Reply With Quote
Old 04-07-2012, 06:59 AM   #2
oldsinner111's Avatar
Drives: s320 and 300sd
nate rector
maybe this will help I had to replace pulley at 150,000 miles
__________________
1999 S320 plus 125 nitrous shot hp,modified grille area,and cold air intake,wrapped exhaust manifold,wrapped air duct,cold air,ceramic pads,no cats
Borla exhaust one muffler14.4 1/4 mile 1983 300 SD not stock Mobil One ATF diesel rated oil both cars
The Runaway Files by Tennessee Nate
oldsinner111 is offline   Reply With Quote
Old 04-07-2012, 01:54 PM   #3
Drives: 96 S500
Hey, thanks for the reply. However, didn't see any information attached except "1999 S 320 nitrous, 300sd not stock" in the reply section? oh...and that you changed yours at 150k miles. Outside of that i didn't see any additional information. Can you resend? or elaborate? Thanks
Old 04-07-2012, 03:37 PM   #4
nate rector
the pullys are a maintenace item to be replaced
__________________
Old 04-07-2012, 10:41 PM   #5
Drives: 96 S500
So based upon my description of the sound etc.....you think I should replace the "pulley" ONLY or the ENITIRE smog pulley air pump component which consist of pulley? What do you think? Just wondering got a guy parting out another 90 S500 what will sale me entire pump for $150 if I pull it. He's got 78k miles on his. Let me know what you think? Thanks
Tags
500, air, bearing, coming, forum, mercedes, pulley, pullys, pump, pumpsmog, replace, replacement, s500, sel, smog
Search this Thread:
Advanced Search
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Copyright © 2001-2012 InternetBrands, Inc. / MBWorld.org. All Rights Reserved.
Everyone's Personal Details
SEO by vBSEO 3.5.2
