S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
cranking but no start. no 12v at fuel pump
Old 02-09-2013, 09:12 PM
w140forlife's Avatar
s320 s420 s500
hello,
recently my cousins (7-94) s320 its been having some starting issues.
it started by running fine until one morning the car wouldn't start. it would keep crank and crank but would not run . after a few days staying in the driveway would start without a problem would run and drive fine for a day or so and all in a sudden the problem persists again cranking but wont turn over . started by checking fuel pressure but there is none in the fuel rail changed the fuel pump (30a) fuse in the trunk and fuel pump relay and still no difference, tried to test the voltage at the fuel pump plug wire and there is 0 volts with the key in position 2. what would the problem be a bad ecu unit , a bad cps or ignition module.?? and also which one is the LH and ecu in this box. thanks all
Attached Thumbnails cranking but no start. no 12v at fuel pump-wp_001383.jpg
Old 02-10-2013, 11:57 AM
oldsinner111's Avatar
s320
ignition switch maybe
My case no pump or fire.I had been having trouble with my ignition switch now it quit .Mine has 170,000 miles,so it made it that many key ons.
Might be your problem.I don't know if pump has a relay,there are several in the trunk
Old 02-10-2013, 01:30 PM
s320 s420 s500
thanks for your reply. yes there is a 30a amp fuse for the fuel pump in the fuse box in the trunk and also next to that fuse box there is the fuel pump relay as well. changed those both and still no difference no fuel pressure at all in the fuel rail. car cranks and cranks but wont start. if the key is worn out does that have to do anything with the fuel system by preventing the car to no start but only crank?
anyone else experienced this on their s320's?
Old 02-10-2013, 02:26 PM
s320
key
It might but I believe in might be the switch,there plastic
Old 06-19-2014, 08:51 AM
CLKTHEO's Avatar
1998 CLK320 Cabriolet
Did you resolve the problem?
Hi im having a similar problem did you resolve it? could you pass on any info that could help me please?
Thanks for your time.
Old 03-05-2015, 09:03 PM
Delamoya's Avatar
S500 w140
Try replacing the fuel pump? My guess would be the pumps have failed.
Old 03-09-2015, 12:55 PM
burgca's Avatar
'97 S500 Coupe, 2016 AMG S63 Coupe, 2007 Audi Q7
If your issue is with a CLK320 M112 engine have you replaced the CPS?
Old 03-10-2015, 08:42 AM
s320
have you checked fuel pump relay,next to rear fuses,they can go bad.
Quick Reply: cranking but no start. no 12v at fuel pump
