S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
change battery safely in a s420 w140
Old 11-18-2014, 11:10 PM
rockcoolo's Avatar
s420
Hi I was wandering how to pull out old battery from s420 w140 without doing damage to car Where can I get the radio code if needed I just bought a s420 and am learning cheers
Old 11-29-2014, 09:10 AM
RYM718's Avatar
99 S420
Passanger side unscrew the bolt from the bracket that is holding the battery down. Disconnect the terminals and replace the battery. For the radio code what you can do is take the radio out to get the serial number. It's going to be a long number on the side of it. Go on http://www.radio-code.lt/ and search the data base. I was able to get mine with out a problem. Good luck.
Old 12-02-2014, 03:11 PM
oldsinner111's Avatar
s320
w140 last of the diy friendly cars.Battery change is easy,resync your windows,and punch in radio code.
Quick Reply: change battery safely in a s420 w140
