S-Class (W140) 1991-1999: 300 SD, S 350TD, 300 SE 2.8, S280, 300 SE 3.2, 300 SEL 3.2, S320, S320L, 400 SE, S420, 400 SEL, S420L, 500 SE, S500, 500 SEL, S500L, 600 SE, S600, 600 SEL, S600L, 500 SEC, 600 SEC
Keep blowing the #11 fuse central locking
Old 01-10-2015, 12:20 AM
samm1234's Avatar
1998 s 320
Came out this morning and couldn't unlock car or open trunk. I used my key to access car checked #11 fuse and it was blown , I replaced it and went to lock car with remote and it took out the fuse again. WHAT IS MY PROBLEM?Please help if u can.
Signed: Unlocked in Jersey
Thank you.
Old 01-12-2015, 12:52 AM
hellah fresh's Avatar
Was 89' 300E, Now 93' 500SEL
I had the same problem with my car. I kept blowing my fuse and everytime i replace it, lock my car the next day the fuse is blown. ON my car the PSE pump was going bad. The motor kept running without shutting off so it blew my fuse. Double check your PSE pump in the rear seat. A good indication if the pumpe motor is bad.. you can smell it. Like metal burning.
Old 01-12-2015, 10:21 AM
samm1234's Avatar
1998 s 320
Thank you for your reply.i will look at the PSE today . Other than eBay is there a auto parts supplier that u can recommend that would sell a recondition part.
Thank you
Quick Reply: Keep blowing the #11 fuse central locking
